Ricoh Pro C5100s help please!
    • 37513
    Re: Ricoh Pro C5100s help please!
    Universal print drivers were intended primarily for use with pooled printers of different make or models. To be pooled all printers must use the same driver.
    • newguyhere2
      • 7
      Good to go! Changed the service mode settings above and removed the fiery NIC. Printer is printing correctly! Thanks to all that reached out and helped.
      • stuinthecity
        • May 2023
        • 4
        So shot in the dark since this thread is pretty close to my issue... Just got a Ricoh pro c5200s and trying to use without Fiery and print direct from computer. Managed it with my previous 5100s but can't figure out the SP settings to change for the 5200. Are there more changes needed than just 5193 and 5895?
        Thanks!
          • 37513
          #19
          Start a new thread GRAVE ROBBER
