Ricoh Pro C5100S and Fiery E42B Connection Issue
  • Kozprint
    • 34
    Can ping back and forth, even see the machine thru Web Monitor but can't print to it. Made sure everything was reset to original settings when it supposedly worked, tried multiple setting variations on Fiery and C5100. Tried new cross over cable. All lights on for network card connections. Been a while since I've had to do a Fiery connection troubleshoot. About ready to suggest client remove the Fiery and use the internal set up if possible. Any suggestions?
    • 30407
    Re: Ricoh Pro C5100S and Fiery E42B Connection Issue
    Can you web into the fiery?
    Any error on the fiery?
    • Kozprint
      • 34
      Yes.
      Error: Check copier power and cable connections
        • 30407
        Reboot fiery and turn off copier boot the fiery up first than wait 3 mins and turn on the copier
        Sounds like its not synced
        • Kozprint
          • 34
          I've tried that several times, probably never waited 3 minutes, but I'll know in the next 5 minutes if that works.
          • Kozprint
            • 34
            No, that didn't work.
              • 30407
              ok turn off copy boot fiery until fiery is ready than turn on copier.
              • Kozprint
                • 34
                Tried again, no luck.
                Here's the thing that's odd IP Address for Server is 192.168.1.140
                Copier is set to auto obtain but the IP address comes up 169.254.139.173 with Subnet mask 255.255.0.0 which I believe isn't correct.
                On the older Fiery's the IP addresses would be the same and subnet would be 255.255.255.0, which at one point this one was.
                  • 30407
                  169 means no network connection
                    • 37560
                    Both the C5100 and the Fiery have 2 Ethernet ports. The gigabit port is for connection between the Fiery and the C5100 only. You may have one or both of them connected wrong.
                    • Kozprint
                      • 34
                      Then that would leave me to believe there's some sort of problem with the network card in the copier. But at one point I could ping between the server and the copier and view the copier through Web Image monitor.but now I can't so I'm assuming there's some sort of cascade failure going on some where.
                        • 30407
                        If you could ping both before and web in there nothing wrong with the nic cards.
                        Power off all and unplug each for 30 seconds than start the fiery first than 1 min start the copier
                        • Kozprint
                          • 34
                          I know they're connected correctly. I tried the other connections just because I was down to a hope and a prayer.
                          • ThePomqueteer
                            • Sep 2016
                            • 73
                            I luckily have one just a few feet from me.
                            On back of copier, cable is plugged into center leftmost port, going to back of Fiery's RJ45 lowest port
                            Fiery RJ45 upper port is going to our network router
                            Copier has an IP range in system settings, interface settings in same IP range as fiery
                            Copier is 192.168.0.20 (example)
                            Fiery is 192.168.0.30 (example)
                            If its showing 169 thats usually APIPA which means its looking for a DHCP and can't find one meaning you'll need to set it statically or leave it on DHCP and maybe your cables are connected wrong which is why it can't find DHCP.
                            One thing that confuses me though is that you said you got on the WIM but I don't know how thats possible when it can't find the DHCP server. Did you do something between that?
                              • 30407
                              So what's the status Now?
