Ricoh mpc300 Network Connection failure
  • Jama
    • Jul 2020
    • 49
    Re: Ricoh mpc300 Network Connection failure
    Originally posted by keithxxiii
    Plus 1 with Dr. Phil's IEEE 802.11 enabled.
    Just a thought maybe worth sharing about subnets.
    Online IP Subnet Calculator
    Yes, IEEE 802.11 enabled but still not working,
      DISABLE 802.11
      • Jama
        • Jul 2020
        • 49
        DISABLE 802.11
        I did it before , no change
          • 37375
          #19
          Originally posted by Polarbear
          Just a thought....
          while at the customer, remove the network cable from the machine port, and check the pins with a torch. We had it before, when someone tried to plug a usb cable into a network port and messed up the pins inside the port - which meant that the network port would not work at all as some pins were bent and some were touching.
          I have also seen the outer 2 pins bent down by someone accidentally plugging the connection cable for the fax into the network jack.
          • sandmanmac
            • 3979
            #20
            First....you didn't answer the question as to whether the machine was previously working and has since stopped, or if you have acquired the machine and are having a problem getting it setup. I imagine that it's the latter.
            On the configuration page under "interface Information" is there a 'network range' set?
            If so, that's the issue
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              #21
              This must say inactive if active it not pick up any information you will get 11.22.33.44 on dhcp
              Regards Mark
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                #22
                If I have a used machine to install this is what I always do just in case it had any account software or papercut Inc installed
                In factory mode reset to default that's 58xx xx6
                Then format hdd
                Then clear all nvram apart from 1 & 2
                Reboot machine it should be in dhcp once this is done let it pickup all information then add on one pc to test then print off full configure page then input in static then reboot
                Update all firmware input Tel numbers and set to show toner levels on lcd
                Iq very rarely have problems after that
                Regards Mark
                • sandmanmac
                  • 3979
                  #23
                  Then format hdd
                  Great steps and advice! That's pretty much exactly my process too..... Except also disabling that stupid WSD functionality
                    • 37375
                    #24
                    IEEE 802.11 is normally enabled for one of two reasons.
                    1. Ricoh's extremely over priced WiFi interfaced
                    2. High security authentication such as Kerberos is enabled
                    Option 2 requires other settings in both User Tools and SP that could be affecting network operation. Print and analyze non defaults.
                    • tsbservice
                      Field tech
                      • 7981
                      #25
                      If NIC port of machine is working - not physically damaged, you really should start with basics.
                      Connect your laptop with your own Ethernet cable to the machine. Set them on the same network and do ping -t test for 2-3 minutes. If it pings OK install appropriate driver for the model. No WSD port should be used. Do test print.
                      • sandmanmac
                        • 3979
                        #26
                        I would add a 3rd option - and the one that I run into most frequently after a machine has been installed and working.
                        In my case, it's typically either a nosy, inexperienced employee, or an anal retentive IT person that fools around in user tools and decides that enabling it, is a way to connect it to their wireless network, and then forgets about it, when the machine no longer does anything, and then everyone in the office turns into a 5 year old child, refusing to admit that anyone touched anything, when they call me and I explain it to them
                          +1 on the office folks and dumbass IT folks.
                          • keithxxiii
                            Just a tech
                            • Nov 2014
                            • 468
                            #28
                            Throwing my last suggestion here. Initialize the NCS. Be careful, NCS only
                            Aye! Cut the crap
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              #29
                              Sometimes it would be great to the outcome.
                              Regards Mark
