printing on envelopes via bypass
  • fshead
    • 2376
    hey i want to know is there any way to feed envelopes on a mpc401 via bypass?
    if i do it closed face up it prints on the backside with the seal..
    I did it thru paper tray and that works but i like bypass as an option..
    I am not sure if it is at all possible but figured id ask..
    thanks
    • 30409
    Re: printing on envelopes via bypass
    thanks
    turn the envelope over
    • fshead
      • 2376
      i did that but sometimes customer might load it wrong or flap might sit up and impede
      transport thru copier..
        then have them feed it through the tray because they are just plain to stupid to learn....
        my customers ALWAYS fed them in the right way, that because THEY READ THE USERS MANUALS!
        you just can't fix stupid
        on most printers/copiers I have worked on the flap SHOULD NOT be closed it should be towards the end of the tray and opened up. But then again I worked on High end.. and middle class machines
        • anothertech
          • 1771
          So you are saying the customer loads the envelope upside down and then it prints on the wrong side?
          We should put in a request to Ricoh to enable a "print on the other side of the upside down envelope" feature?
          • fshead
            • 2376
            NAH if you feed face up via bypass the image is on the flap side..
            on paper tray it works............
              • 16455
              Hopefully you can help me out with a problem I have. In my car when I press on the gas petal, the car goes and when I press on the brake it stops. I want to be able to press on the brake and have the car go. Help a brotha out?
              • fshead
                • 2376
                i make a living on "stupid".........
                i just tire of dumb calls.........
                when feeding thru bypass the backside gets the image,i see no way to change that...
                i guess in my mind i am i asking to do something design can not allow...
                  sure swap the linkage from one to the other.
                  silly wabbits brakes are for pussies
                  • tsbservice
                    Field tech
                    • 8032
                    Load envelopes into the Bypass Tray with the print side facing down.
                    When loading envelopes, remove air from them, and securely press along the flap fold line. Otherwise, it will result in an envelope wrinkle or paper jam.
                    Do not use envelopes that have glue or release paper on the flap or the part covered by the flap on the body. Otherwise, the machine may be damaged or a failure may occur.
                    All excerpted from User guide.
                    Also I will print a picture how to put envelopes and stick it up over machine.
                      in every manual I EVER read.. it shows the image process and feed direction.
                      what program are they printing from? Word? Mail Merge? proprietary program ( if this is the case the makers of that program will have to get involved )
                      what print driver are the using?
                      you will have to LOOK at the program they are using to print envelopes from... make changes to the print driver and compare to the program print process.. you are there we are not.
                      I seem to remember another thread recently with the same sort of problems.
                        user guide always handles issues like this.. just some users are tooo DAMN lazy to READ it!
                        thanks brother!
                        • fshead
                          • 2376
                          thanks brother!
                          I am too lazy to read it too..
                          way too many other things to do that are taking my time.........
                            • 16455
                            No offense, bro, but I imagine the techs on this site are busy, too, and you should really trying to find the information before asking them to do the work for you.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
