mp c2011 scanner issue
  • Marwanalhajbi
    • Jul 2018
    • 72
    there is a long horizontal line appear on scanned paper on right side ,when i use the ARDF or GLASS same issue happens and when i print same scanned paper it lifted for 1 cm ,if i put the paper vertically same occur but the line come vertically as well
    as shown belowscanned.pdfprinted the scan.pdf
    thanks alot
  • sandmanmac
    • 3990
    Re: mp c2011 scanner issue
    So what happens when you print something that you HAVEN't Scanned?
    Because it appears to me that the line on the scanned image is the edge of the paper due to either a slightly reduced image OR registration , and the line on the printed image is SAME LINE because you are printing the image reduced even more, If I select "none" under "scale "in the paper paper handling section of my PDF veiewer the line is gone because the margins are wider
    C'mon man, this is the most basic troubleshooting there is!
      • 37624
      There is a bit of dust or hair on the first mirror.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        as shown below[ATTACH]46581[/ATTACH][ATTACH]46582[/ATTACH]
        thanks alot
        Are you scanning a4 or a4r
        Regards Mark
        • Marwanalhajbi
          • Jul 2018
          • 72
          I apologies for my poor skills in ricoh,
          however the line appears only in MPC series ,meanwhile i tried to make a scan on aficio mp c2551 no line at all on any edge,that why i'm asking how to solve this issue,
          my question is there any way to make a scan without a line appear on the edge ,our i have to convince the buyer that is normal??
          thanks to ur kindness
          • Marwanalhajbi
            • Jul 2018
            • 72
            A4 sir
            • Marwanalhajbi
              • Jul 2018
              • 72
              sir,
              if i rotate the paper it also appear on the last edge of it
              please see the attatchment
              20200825085454235.pdf
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                It's probably a scan size setting in the user tools that's if it the same from glass and df but if only happens from df it could be registration settings in service mode
                Regards Mark
                • mikadonovan
                  • May 2008
                  • 2931
                  That's the first place I would go after an ADF cleaning.
                  NEVER ASSUME ANYTHING
                  • sandmanmac
                    • 3990
                    So you have yet to even respond to ANY of the suggestions you've been provided by several people!
                    I'll ask you again....Is the registration off? Adjust it in SP mode!
                    Is the image reduced? ( My bet is that it is)
                    Make a copy through the ADF and then hold it up to the original and check Registration AND magnification.
                    I bet that the copy is reduced 2-3mm...thus the line (edge of paper)
                    If so, Adjust ADF magnification in SP mode (6xxx) by about -1%.
                    EDIT: I forgot to add that the reason I returned to this thread is that I literally had (what appears to be) this exact issue on an MP C3003 that I just picked up today. I Adjusted ADF magnification. All good
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 471
                      Maybe changing your DF Lead Edge, or Trailing Edge will resolve the issue.
                      Aye! Cut the crap
                      • GIUBOSS
                        • 1437
                        get the technical manual if you don't know the machine, if you know how to enter sp mode check the feed and adf values ​​if they coincide with the birth certificate, if any.
                        • Marwanalhajbi
                          • Jul 2018
                          • 72
                          thanks,it was from ADF registration from sp mode ,i register it and the machine is working fine
                          • Marwanalhajbi
                            • Jul 2018
                            • 72
                            thanks it was adf registration
                            • Marwanalhajbi
                              • Jul 2018
                              • 72
                              EXACTLY,that was the problem thanks to u
