sc 546 on 2045 HELP!!
  • ash_572
    • 523
    This sc code is the most difficult fault to get rid of for good! Keeps recalling every few days. Changed hot roller, thermistor, cleaning roller all genuine parts and correct part part numbers fitted in according to manuels. Lamps and thermostats all working. Its making me look like a right twat! Seems like a common fault on these 2045. How do i fix it?
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    First, is all of the firmware up to the latest version?
    Second, is the power to the copier clean? I know that a 547 is for dirty power, but fluctuating power, as we all know, causes weird crap sometimes.
    Given that you have changed out most everything, you might have a fuser connector/receptacle that is losing connectivity when it gets hot.
    On a previous version, the 1035/45 series, we fought with one and it ended up being the fuser receptacle in the copier that finally fixed its 542 problem.
    Regional slang is so funny; I see the word twat and can pretty much guarantee you that in my mind, a "right twat" would be as good as a "left twat" and that it does not mean here what it means on your side of the pond.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • Fearless V K
      • 620
      My money would be on the fuser connector at this point. Had one like that before. Changed everything. Kept coding. Swapped the connector and all was good.
      Don't take that toner with me!
      • tungnhung
        • Dec 2008
        • 26
        Zero Cross Signal Malfunction
        Fusing/Hot Roller Temperature Does Not
        Increase
        • Star
          Ricoh Tech
          • 127
          I concur. Connector on back of fuser (these get cooked over time), or connector on machine side.
          Regards
          • KopyKat
            Nurse Ratched of Repair
            • Nov 2008
            • 366
            I agree that the connector is most likely.
            Just a thought....Another thing I have seen is power fluctuation to the machine. Set SP1104 (Temp Control) to Phase Control and then reboot the machine.
            sigpic
            Relax! This firmware injection won't hurt...but it will take 45 minutes.
            • sandmanmac
              • 3975
              The fact that it's 'every few days' leads me to power fluctuation as well. A good surge supressor should take care of it - It has for me in several locations.
              • E Winter
                Regards
                yes I had some trouble with these connectors too - the last times I just cleaned the contacts with contact spray and slided the fusing unit in and out for ~20 times and some force and that seemed to be a good and time-saving workaround
                • bonnie750
                  • 302
                  SCHOOLTECH.......
                  On this side of the pond and in this context it means to appear to be a 'complete and utter incompetant'
                  • schooltech
                    • Jun 2008
                    • 504
                    Yeah, I kind of figured that. But, here it means a slightly different thing-and the U.S. techs will concur.
                    So, how's the problem looking? Have you been able to swap the connectors and checked the power?
                    • ash_572
                      • 523
                      i ended up replacing the whole fuser unit instead of repairing it. looks like its ok now, not come back in yet. so its definitly within the fuser unit. rekon it was the rear connector of the fuser unit that was causing this 546. connectors did seem a lil loose.
                      • Lagonda
                        • Aug 2008
                        • 1649
                        "a right twat" would be as good as a "left twat"
                        A woman with two twats!!!!! I'd like to meet her!
                        • claudioterrible
                          no mercy...
                          • 96
                          sc 546
                          hi ,we had everal problems with this sc,everything looks ok,and we discovered that the problem was we were using ktn hot rollers and these rollers doesn t work well,there are little differences with the original,we replace and use the original and all works fine
                          • schooltech
                            • Jun 2008
                            • 504
                            Twins my friend, twins
