Savin MP c3002
  • tysonkuchta
    • Aug 2025
    Savin MP c3002
    Hey hey copytechnet, I am the end user of a Savin MP c3002 and I am getting the error code SC672-00 I am not factory trained but I have been talking with a service tech that does not live close by me. so far I Replace the D1425110 BCU and the D1425712 PCB and I'm ending with the same code at start up. does any one have some pointers for me ???
    Thanks so much ,
    Tyson
    • 16416
    Re: Savin MP c3002
    The error code 672 or SC672 is a controller startup error. It could mean the controller board is installed incorrectly or has gone bad. It could also be a simpler solution such as a connector somewhere is not securely fastened.
      Re: Savin MP c3002
      Thanks so much , Tyson
      did you CLEAR the error after replacing the boards?
      did you hook them up properly ?
      did you swap over the NVRAM from old to new?
      so many questions so few answers ...
      this SHOULD have been handled by a TRAINED service tech with THE MANUAL! There are certain procedures that MUST be followed PRECISELY IN THE PROPER ORDER!
        • 16416
        Re: Savin MP c3002
        Yeo, and are these new or used PCBs? If used, do you know for sure they were working...did you actually see them in a working machine?
        • sandmanmac
          • 3981
          Re: Savin MP c3002
          Thanks so much ,
          Tyson
          SC672 is one of the most wide-ranging error codes. It seems to be generally caused by a power surge that shorts out something.
          A couple of other things to try is remove/disconnect the Fax board (if installed), and also disconnect the HDD and try booting up the machine.
          If it boots it's obviously caused by one of the 2. Re-connect 1 at a time to determine which one.
          You might not even require the fax these days. If not, then you're good to go. But if it's the HDD, then you'll need to reformat/ replace it in order to use many features - specifically scanning.
          * Note if it does boot up without the HDD connected, you will see some error messages flashing in the bottom of the screen (Generally SC8xx) indicating an issue with the HDD.
          • copier tech
            • 8174
            Re: Savin MP c3002
            Thanks so much ,
            Tyson
            Put all the original boards back on & see if the machine will accept a firmware update.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Re: Savin MP c3002
              Thanks so much ,
              Tyson
              Hi you shouldn't start by replacing boards put the old pwb's back on and start from there
              Regards Mark
