Lanier LD645C
  • stevee104
    • Mar 2007
    • 214
    Lanier LD645C
    Customer email these pictures of the transfer unit, i have no manuals for this machine
    because we are a Kyocera dealer and they have 3 km on site. What are we looking at replacing here
    and is the parts still available. I did some searching and all i can come up with is a transfer guide
    plate assembly.
  • anothertech
    • 1762
    Re: Lanier LD645C
    That's the same as a Ricoh MP C4501/MP C5501
    Here's the tech pub that shows you what to order, I have no idea if these parts are still available.
    Transfer Roller Case.pdf
      • 37386
      Re: Lanier LD645C
      If you compare you photos with the illustrations in anothertech's reply in the area where the the metal plate is on the now style case you will see where the plastic has broken. Ricoh still used the same or similar in the C4502 so should still be available.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Lanier LD645C
        D0894551, just replace the lot.
        Hit it.
        • davel
          • Oct 2011
          • 1095
          Re: Lanier LD645C
          May also need Guides front and rear D0296318,D0296319, also stopper D0296316.
          • stevee104
            • Mar 2007
            • 214
            Re: Lanier LD645C
            Thanks guys for quick response , i think i am going to replaced the whole thing if i
            can get it, unless you guys have a used one you want to sell.
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: Lanier LD645C
              Found a couple on ebay:
              Hit it.
              • skinnyb
                • Jul 2008
                • 291
                Re: Lanier LD645C
                This. I replace the whole assembly. It has all you need with the exception of ... D0296316, D0296318, D0296319. Order them all and replace them all, and if it's real bad and ripped the belt get a belt too D1446091 and the cleaning unit D0896022
                Sent from my LM-V405 using Tapatalk
                • stevee104
                  • Mar 2007
                  • 214
                  Re: Lanier LD645C
                  Thank you will get them ordered next week ,
                  taking a long weekend off.
                  • fshead
                    • 2367
                    Re: Lanier LD645C
                    i would pull the whole right door assembly off and shake it out as you will have a lot of small plastic that could cause damage or jamming once all is
                    put back together..
                    • fshead
                      • 2367
                      Re: Lanier LD645C
                      and i would check that top assembly with the white ribs as that piece usually cracks and causes issues..
                      FROM heat and time the plastic becomes brittle and easily broken...common on a lot of the older ricoh colors...
