MP601 SC670-01
  • tufbnme
    • 493
    MP601 SC670-01
    First time putting eyes on this model. The book doesn't really pinpoint this issue.
    Anyone seen this?
  • copier tech
    • 7931
    Re: MP601 SC670-01
    Anyone seen this?
    Same as any other Ricoh with this error try updating firmware before replacing any PCB
    • Code: SC670-01
    • Description:Causes:Engine board does not start up.
    • tufbnme
      • 493
      Re: MP601 SC670-01
      Thanks for the reply. Cannot update FW. Will not recognize SD card, cannot access service mode, nothing.
      • Code: SC670-01
      • copier tech
        • 7931
        Re: MP601 SC670-01
        Most likely a failed controller.
        But before you order a new one reseat all the connections & ram etc.
          • 35061
          Re: MP601 SC670-01
          If it is an "Out Of Box" failure when you first set it up, contact Ricoh for warrantee replacement.
