MPC306 printing & scanning WIFI
  • GeorgeBest
    • Jul 2009
    • 526
    HI,
    Not much experience on using WIFI on this device, but
    when I activate WIFI modus, I can print from any PC to the MPC306 using only the WIFI mode.
    But when I try to scan (and also use webinterface) it doesn't work !
    Trying the webinterface I get no connection on any browser
    trying to scan to email it says "wating"
    So I can print, ping also works . . . . anything to do with Firewall or proxy ??
    Thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MPC306 printing & scanning WIFI
    If you're using the wifi in the panel, you can only print. You need the proper GW wireless option for full wireless functionality.
    Hit it.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by GeorgeBest
      HI,
      Thanks in advance
      These machines don't have WiFi as standard the WiFi on the control panel {smart} is just for the panel you have to connect to a WiFi router then will print and scan WiFi if that's what you have done. It must not been set up correctly all ip and dns must be set up in interface section and the set up smtp in file transfer section. All this would be in the user guide
      Regards Mark
      • GeorgeBest
        • Jul 2009
        • 526
        The WIFI on the panel is not complete and only for printing?
        • GeorgeBest
          • Jul 2009
          • 526
          This machine has standard Wifi, you can search for wifi points, log in and make a connection with it.
          It gets an Ip adres. Testing without cable and prints do come out.
          But why does it not scan and make a login with the web interface . . . ?
          • copier tech
            • 8236
            HI,
            Thanks in advance
            The wifi in the SOP is not designed to be used with a PC etc however it does give you limited print functions but you are not using the GW Controller.
            You will not be able to scan while connected this way SMB or email.
            • GeorgeBest
              • Jul 2009
              • 526
              Same with the MPC307 ?
              • copier tech
                • 8236
                Yes same with ALL models with the SOP.
                • GeorgeBest
                  • Jul 2009
                  • 526
                  Ok, Thnx!
                  • pajonk22
                    • Oct 2019
                    • 1
                    u can use WIM with machine connected to Wifi. U need to use non-standard port: http://[device ip]:53080
