MP 5054 jamming
  • anothertech
    • 1771
    #16
    Re: MP 5054 jamming
    Originally posted by Codex
    i have the same problem at a customer, random duplex jams in the inverter section,already changed the inverter section, but the random jams remains,they are very random..sometimes once a day or so, sometimes more, logging a "duplex exit jam"...maybe some sensor???
    Two things here, First what is the jam code, Second you should probably start your own tread.
    • Mark Bbb
      • Jun 2012
      • 1662
      #17
      Re: MP 5054 jamming
      I
      Codax, is paper folded when jamming?
      • Codex
        • May 2008
        • 705
        #18
        Re: MP 5054 jamming
        Originally posted by Mark Bbb
        I
        Yes... If everything works fine, the paper comes out from the exit section for ca. 15cm,then goes back in the machine for duplexing......but before it is about to jam,the paper comes out only 1 or 2cm...and then jams... I find the paper folded on the fuser unit
        Inviato dal mio SM-G935F utilizzando Tapatalk
        Memento Audere Semper
        • Mark Bbb
          • Jun 2012
          • 1662
          #19
          Re: MP 5054 jamming
          i think you should start another thread for this as someone has already mentioned here.
          • Codex
            • May 2008
            • 705
            #20
            Re: MP 5054 jamming
            Yes... I'll start a new thread
            • davel
              • Oct 2011
              • 1108
              #21
              Re: MP 5054 jamming
              Does it come out of the normal paper path exit or the upper duplex exit.
              • Codex
                • May 2008
                • 705
                #22
                Re: MP 5054 jamming
                On the duplex paler path first
                • johnnyquest
                  • Feb 2020
                  • 16
                  #23
                  Re: MP 5054 jamming
                  if it has a finisher, faulty bridge switches will not log a jam, but it really sounds like the exit unit
