Old Ricoh FT4421 Error Code E2
  • Missionstreet
    I have an old copy machine I was just wondering if anyone knew what the error codes were in 1991 for a Ricoh Copier.
    I'm getting E2 on the display. Called customer support but they have no clue. Go figure. Thanks in advance.
    • 23010
    Re: Old Ricoh FT4421 Error Code E2
    Check fuse 101 on the DC power supply.
    I don't have an explanation of the code. =^..^=
      • 37556
      That is so old that I don't even have any manuals. I do have a listing in the April 2003 B/W Analog Read CD index that identifies it as Product Code A054 discontinued in May 2000. Gooses Guide has some problems for it but not E2.
      • ThePomqueteer
        • Sep 2016
        • 73
        I found the FT2260 service manual on the RFG website so I'm not sure if the error codes would be the same but if it is, it shows that there should be a second code (E20 - E24, E2U, E28, E2A-D)
        Is there a subcode or just the E2?
        • bob marley
          • Jan 2012
          • 1339
          do u mean E2B?
          Live for yourself and you will live in vain. Live for others, and you will live again
          • blee
            Technical Trainer
            • 54
            Been awhile but you have to hold down another key to get the rest of the error code. Maybe it was the enter or something like that and that should give you extra digits to get the full code. But E2 codes of any sort back in those days usually dealt with an issue in the scanner area.
