Mp4054 random duplex jams
  • Codex
    • May 2008
    • 683
    Hello
    As suggested i started a new thread for this problem.
    I have a Mp4054 with random duplex jams.. Very random, the customer says it happens only on cold machine and only during prints, but in the log i saw that i happened even after a print job of 200-300 sheets. During the service the machine jammed only two times at the same way,the first was a print.. The second a SMC printout... It seems that the paper comes out from the duplex tray for only a few centimeters, then feeds back in the machine and jams there,when everything works fine the paper comes out for about 15 cm and then feeds back in the machine. Six months ago we changed the Fusing Sleeve Assy and the entire duplex exit section for this random jams, i thought there was a faulty solenoid in the duplex unit. But now the problem is back (the customer was closed during lockdown, so he couldn't try the machine).
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Mp4054 random duplex jams
    And the paper is folded...
    That could mean that the exit sensor (or duplex sensor) is faulty, but that is not necessary so.
    At which spot / location does it indicate the jam?
    • Gab
      • Aug 2015
      • 633
      clutch
      • Codex
        • May 2008
        • 683
        The location is J27 "Duplex Entrance"
        • Codex
          • May 2008
          • 683
          Originally posted by Gab
          clutch
          Wich?
          • mikadonovan
            • May 2008
            • 2936
            Just a thought, is the paper full of moisture and causing feeding problems? You said they were closed during the lockdown, that means the machine was just sitting for a long time.
            NEVER ASSUME ANYTHING
            • johnnyquest
              • Feb 2020
              • 16
              replace the exit assy, it warps and causes issues
              D2024405
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                clutch
                No clutch in duplex
                Regards Mark
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  +1 see if starts to roll on single side
                  Regards Mark
                  • Codex
                    • May 2008
                    • 683
                    Yes.. But i changed paper and the problem remains
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      is the registration of the image on the paper correct?
                      • zed255
                        How'd ya manage that?
                        • 1025
                        Seen intermittent jamming due to fusing sleeve becoming dry and difficult to turn. Causes slight delay in paper transport that may not be an issue in simplex but becomes an issue in duplex. If it is a lightly used machine the fuser sleeve may be well under rated yield.
                        • guitar9199
                          • Sep 2016
                          • 1097
                          Following the "KISS Principle", how many clicks on this machine? If it's over 150K, you might want to start with new feed/separation rollers, check your torque limiters, and cleaning all the rollers in the feed and duplex path.
                          If it's just "randomly" jamming, that's my go-to starting point.
                          • Codex
                            • May 2008
                            • 683
                            Hello guys
                            Changed Friday all three sensors in the exit unit, tried smc printout (3 times) and everything ok.... Customer prints ONE sheet (duplex)... And again J27!.... I start to think that there is a problem in the network or so (already tried pcl6 and pcl5). The other thing is that this machine has a different exit unit as other machines we have around, it looks like a kind of motorized fax exit, other machines have only a simple plastic exit tray.
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Originally posted by Codex
                              Hello guys
                              Hmm, it could be that heat is an issue. I had that once! Cold duplex, no problem, but after a while it jammed.
                              Duplex guide?
