Mp4054 random duplex jams
  • luca72
    • Oct 2017
    • 1778
    #16
    Re: Mp4054 random duplex jams
    Originally posted by Codex
    Hello
    As suggested i started a new thread for this problem.
    I have a Mp4054 with random duplex jams.. Very random, the customer says it happens only on cold machine and only during prints, but in the log i saw that i happened even after a print job of 200-300 sheets. During the service the machine jammed only two times at the same way,the first was a print.. The second a SMC printout... It seems that the paper comes out from the duplex tray for only a few centimeters, then feeds back in the machine and jams there,when everything works fine the paper comes out for about 15 cm and then feeds back in the machine. Six months ago we changed the Fusing Sleeve Assy and the entire duplex exit section for this random jams, i thought there was a faulty solenoid in the duplex unit. But now the problem is back (the customer was closed during lockdown, so he couldn't try the machine).
    Inviato dal mio SM-G935F utilizzando Tapatalk
    I had the same problem a few weeks ago (J27), to do first I replaced the paper exit / reverse unit on the machine, I have not yet had time to restore it in the laboratory, but I am sure it is a sensor
    "I'll be back"
    • Codex
      • May 2008
      • 704
      #17
      UPDATE!!
      Hello guys
      The problem was caused by the BIN TRAY BN3110......i removed the tray one week ago and no more jams.... Till today....the machine works fine e with a normal exit tray.
      Thank you for al your suggestions
      Memento Audere Semper
      • Mark Bbb
        • Jun 2012
        • 1662
        #18
        UPDATE!!
        Hello guys
        Keep in mind that when a B.U. is installed, paper guides needs to be fit on the exit cover.
        • Codex
          • May 2008
          • 704
          #19
          There is no Bridge Unit installed, only the BN3110
