Ricoh MP C5503
  • heath03
    • Jul 2018
    • 80
    Ricoh MP C5503
    I'm getting a SC370-03 code. it says to clean TM sensor with a cloth but not dry, what should i use to clean them?
    any help is appreciated
    ty
    Heath
    Re: Ricoh MP C5503
    ty
    Heath
    water on the cloth..slightly damp
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Re: Ricoh MP C5503
      +1
      Regards Mark
      • Zaxxon
        • 608
        Re: Ricoh MP C5503
        Beer
        Please start you post with brand, model, problem.
        • heath03
          • Jul 2018
          • 80
          Re: Ricoh MP C5503
          still same code, any other ideas
          • 8T2
            • Aug 2015
            • 257
            Re: Ricoh MP C5503
            In what condition is the ITB? If the print quality is still good I would try raising the upper VSG limit to 5v and dropping the lower threshold to 1v (if possible on these). Old trick we resorted to for SC400 on the MPC2050 engine
            Sent from my WAS-LX1 using Tapatalk
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Re: Ricoh MP C5503
              Check parts life did you see Id sensors pushing shutter out the way 370 03 will be the rear sensor
              Regards Mark
              • Notrons
                • Apr 2016
                • 71
                Re: Ricoh MP C5503
                If all else fails, take the shutter off. It will work without it, will just have to clean ID sensors more often. Of course, it all depends on usage.
                  • 37488
                  Re: Ricoh MP C5503
                  When you clean the TM (ID) sensor assembly it should be done with a soft lint free cotton cloth slightly moistened with water only. Any cloth other than pure cotton can cause static which will immediately attract dust and toner. Use of glass cleaner can leave a film. Of alcohol or any other chemical can damage the sensor.
                  Also clean any and all toner hazing from the ITB assembly. With ITB removed check that the latch cam on the back of the ITB release shaft has not gotten damaged. I had a C6003 where it was broken and caused TM errors. When the solenoid for the shutter energized it would cause the right end of the ITB assembly to move slightly to the front. This kept the shutter from fully uncovering all three sensors.
                  • heath03
                    • Jul 2018
                    • 80
                    Re: Ricoh MP C5503
                    thank you it worked, the machine is back up, ty for the info guys
