Ricoh 2550 Print Not Clear
  • charith93
    • Feb 2020
    • 7
    Hi friends,
    I have Ricoh 2550 and 2050 Machine. those two machine are same problem
    How can i fix this
    I will change main charger/ drum & sponge roll but problem is not fixed.
    Please help me...
    my mail - ckarunanayake@gmail.com
    thanks a lot....
    acheter sildenafil 50 mg preГ§o www.viagrasansordonnancefr.com
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 2550 Print Not Clear
    By sponge roll do you mean PTR? As it is affecting all colours the same it could be ITB, PTR or fuser.
    Hit it.
    • charith93
      • Feb 2020
      • 7
      I mean Charger roll clean white colour item.
      thanks for the reply
      • johnnyquest
        • Feb 2020
        • 16
        looks to me like transfer issues towards the middle of the page. Probable tbelt assy, or even dv unit for magenta
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Originally posted by charith93
          Hi friends,
          How can i fix this
          [ATTACH=CONFIG]46869[/ATTACH]
          Please help me...
          thanks a lot....
          You will need to replace pcu and dev assy most probably
          Regards Mark
            • 37488
            If it were one color only then you would need to replace the PCU/Developer. Since it is exactly the same pattern for all 4 colors, it is must be something common to ALL colors like a dirty PTR.
            • charith93
              • Feb 2020
              • 7
              thanks for the help.
              i change PCU unit
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                I can only see one back ground colour with is magenta also the ptr roller would be colour because the magenta is placing to mush toner on the belt with is going on to the ptr very common problem but sorry if I was mistaken.
                Regards Mark
                • tsbservice
                  Field tech
                  • 8013
                  Looks the same to my eye.
                  However Ricoh are different animals from what I've seen before and work on today so I could be wrong.
                    • 37488
                    I was looking at the light streaks running the entire length through all the colors.
                    • tsbservice
                      Field tech
                      • 8013
                      Those white voids/spots and streaks in my experience could be very well from compatible consumables(toners, etc). OP never mentioned what consumables are used. I always hated to fight ghosts when customers use non OEM parts.
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 469
                        The yield of PCDU as far as i remember is at 80K. It is worth replacing if you have reached above the PM counter.
                        Aye! Cut the crap
                          • 37488
                          60K
                          120K for everything else
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            What i find strange is that the 2 machines have the same problem.
                            Are they in the same room with same customer?
                            What are the counters?
                            Which counter PCU's, ITB, PTR?
                            Is machine standing in normal office conditions?
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              The pcu is 60k
                              The dev unit is 240k
                              Regards Mark
