Ricoh 2550 Print Not Clear
    • 37488
    #16
    Re: Ricoh 2550 Print Not Clear
    Originally posted by mga
    The pcu is 60k
    The dev unit is 240k
    If you are consistent at doing PMs at 60K, thoroughly remove all old developer and toner from the DU and always use only Genuine Ricoh developer and toner the DU might make 240K before stripping the auger gears.
