Scan Browse Network Folders from SOP IM C6000
  • Jason Peterson
    • Oct 2019
    • 6
    I have a customer who wants to be able to have a scan to network folder button on their RICOH IM C6000 and when they press it they want to be able to choose a folder in the sub directory. I know when setting up the address book it only lets you specify one path and I do not see any options for browsing sub folders. Any ideas?
  • anothertech
    • 1771
    Re: Scan Browse Network Folders from SOP IM C6000
    Isn't that how scanning is usually set up? Just default the scanner to folder and then set up the buttons to the sub folders.
      • 37557
      I retired just as the IM models were starting to come out. But do they allow you to use the Classic Scan function. If I remember correctly it had a browse button.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Methinks you are correct.
