ricoh mpc 3002,
  • tullio
    • Feb 2012
    • 268
    ricoh mpc 3002,
    urgent. I have to mount the black drum unit on the color. on a Ricoh MPC3002.thanks, does anyone have the procedure?
  • GIUBOSS
    • 1391
    Re: ricoh mpc 3002,
    If I remember correctly it is the same procedure as in the previous models
      • 37377
      Re: ricoh mpc 3002,
      Search CTN for drum cheat sheet. There have been at least 2 version of it posted.
      • 8T2
        • Aug 2015
        • 257
        Re: ricoh mpc 3002,
        If I'm not mistaken the BK had a larger lube bar and doesn't fit on these.
        Sent from my WAS-LX1 using Tapatalk
        • Zaxxon
          • 608
          Re: ricoh mpc 3002,
          B2242042 drum cut the connector, thats it.
          Please start you post with brand, model, problem.
          • JayPaul
            • Oct 2012
            • 305
            Re: ricoh mpc 3002,
            Yeh if he is referring to the B224 2042 drum, cut connector at back same as usual, swap face plate with original on the drum, pretty sure the one on the new drum has a different guide at the bottom that won't fit.
            • DRichard
              • May 2008
              • 482
              Re: ricoh mpc 3002,
              Does this help?B2C Drum Cheat Sheet-2.pdf
              "Enjoy every sandwich."
              -- Warren Zevon
              • Gift
                • Mar 2011
                • 2458
                Re: ricoh mpc 3002,
                urgent...lol how ridiculous (not the song of course^^)
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Re: ricoh mpc 3002,
                  A oem black mpc3002 will not fit in the colour slot you need to use a mpc2500 black pcu B224 2042 to fit in 02 just file connector no wires need to be swapped over
                  Regards Mark
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Re: ricoh mpc 3002,
                    Try these:
