blank in black
  • johnnyquest
    • Feb 2020
    • 16
    [CQ] blank in black
    has anyone seen an mp c401 give good prints (and copies), but completely blank in black? no residual anywhere. strangest thing is it doesnt code. i can force process control no problem. i have replaced the k pcdu, itb, ptr, hvt, laser, all pcu, and firmware.
  • M94
    • Jul 2020
    • 158
    Re: blank in black
    I'm not quite sure I understand what you're asking, like anything set to monochrome is blank? Or even on mixed docs anything using K doesn't show up?
    Edit> If you can't get black (K) to show up anywhere at anytime then my first thought is that it's not charging properly to attract toner, have you stopped it mid print to see if toner makes it to that point?
      • 16416
      Re: blank in black
      Not a lot of info. What kind of prints do you get in color mode?
      • johnnyquest
        • Feb 2020
        • 16
        Re: blank in black
        in color, you get all colors except black. there is no residual image on the tbelt, or drum. in k you get blank. k pcdu was replaced
          • 16416
          Re: blank in black
          I would think either loss main charge @ black or loss of drive to black DV unit.
          • M94
            • Jul 2020
            • 158
            Re: blank in black
            Maybe a more experienced tech can correct me but that kind of has to mean that the black roller isn't charging properly right? Or the developer unit isn't functioning properly. If the rest of the printer is functional your issue really has to be within 6 inches of that area... Unless it's an oddly specific fault on one of the circuit boards involved, maybe even as simple as a detached or broken cable between the two?
              • 16416
              Re: blank in black
              One way of seeing if black DV is turning is to wipe off all the toner/developer on the mag roller, make a copy and pull the DV out again and see if the mag. roller turned.
              • fshead
                • 2376
                Re: blank in black
                do a sky shot and stop it as it hits fuser unit.
                PULL drums,ITB unit and see if there is any black on the k drum or ITB unit.............
                there are contacts that get dirty in the front that touch the drums/dev units when pushed in..
                bad contact,no charge on charge roller...i know its hard to do and close the drum cover but make sure that lock lever
                above K drum is not mucked up...
                  • 37531
                  Re: blank in black
                  Normally a problem with the drum charge will throw a Service Code, SC. Since it is only K and the color transfer rollers are lifted separate from the K transfer roller, I would say check the ITB assembly to see if the K transfer roller is binding and not pressing the belt against the K drum.
                  • RMC8112
                    • Nov 2019
                    • 38
                    Re: blank in black
                    I ran into a similar issue with a MP C5503 and found that one of the gears was chewed up. I would remove the black PCDU and check the gears.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Re: blank in black
                      OR, you replace the 300 K PDCU and forget to reinstall the drive gear (I speak from experience).
                      NEVER ASSUME ANYTHING
                      • johnnyquest
                        • Feb 2020
                        • 16
                        Re: blank in black
                        thank you everyone for your input. the issue was the k dv clutch
                        • mikadonovan
                          • May 2008
                          • 2931
                          Re: blank in black
                          Glad you got it fixed. That is an odd one. I have serviced a whole bunch of these over the years and never had to replace a dev clutch.
