MP 301 J057 when jamming in the fuser.
  • Stephendupey
    • Oct 2020
    • 10
    [Jamming] MP 301 J057 when jamming in the fuser.
    I have a client where the paper is jamming half way out of the fuser and giving J057. I have replaced all the fuser sensors and the paper feed sensor. I have also replaced the whole fuser but nothing seems to have worked, any advice?
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: MP 301 J057 when jamming in the fuser.
    These machines are so reliable if it's half way out of fuser it's probably a sensor you sure you replace fuser never had to do that just rebuild check paper size all the sensors would of be on new fuser. Was it a new oem fuser?
    Regards Mark
    • Stephendupey
      • Oct 2020
      • 10
      IT isn't a new fuser, it's a working fuser from a refurbished machine in our workshop that had been tested
        are you sure the paper size/type is set properly?
        what happens if you try to print the internal reports?
        • Stephendupey
          • Oct 2020
          • 10
          It jams with those as well, even when printing the counter
            what about my first question to you?
            • Stephendupey
              • Oct 2020
              • 10
              I never checked the paper size, I didn't think that would be a problem as they've only ever printed A4
                customers do stupid shit and then lie about it
                • tsbservice
                  Field tech
                  • 7937
                  Indeed it looks like paper size wrong settings. Make sure someone isn't changed paper tray size or settings.
                  • Stephendupey
                    • Oct 2020
                    • 10
                    I'm going there again in the morning and I'll check the paper size settings
                      size and TYPE
                      • FrohnB
                        • Jul 2017
                        • 1919
                        Along with the suggestions of checking paper size/ type......Make sure that the end fence is in the right position, or not popped out of place.
                        Have seen the Paper End sensor that hangs above the tray become detached and drag on the paper causing timing issue, or it will suddenly flash "Paper Empty" and cause the machine to jam.
                        I agree with the others on here though, most likely a size issue.
                        Omertà
                          • 37047
                          J057 is a trail edge jam. That usually means it thinks the paper is the wrong size, either too long or too short. Just because it is an A4 machine does not mean that A4 is the only size paper that can be pout in it. Just the length difference between metric letter size A4 and inch letter size 8.5X11 is enough to cause a trail edge jam. There are 5.5X8.5 and A5 half letter sizes.
                          • Oze
                            Ricoh Fanboy
                            • Jul 2008
                            • 1663
                            Stoopid question Alert..!!!....did you remember to remove the packing tape that secures the exit flag in shipping?
                            I remember doing that once.....only once.
                            Edit:
                            My bad...just read that you used a s/h fuser for testing.
                            • TonerMunkeh
                              Professional Moron
                              • 3865
                              I've had a lot of problem with the registration sensor actuator sticking and not dropping as quickly as it should causing a lot of trail edge jams. Take it out, clean the bushings it sits in and the sensor too.
                              Hit it.
