Printout on card Ricoh mp c3002
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi Everyone,
    Am having an issue with a Ricoh mpc3002, which do have white stuffs or probably faded output around every print and copy made. I've attached printed copies with this thread. Solution from anyone will be appreciated.
    • 16391
    Re: Printout on card Ricoh mp c3002
    It would be most helpful if you could print out some solid color charts. I'd like to see if those void areas are repetitive. Can't tell from your examples.
    EDIT: Do them for all colors: K,C,M,Y.
      • May 2020
      • 238
      Printed all colors today CMYK. Don't mind the paper, I actually squeeze paper initially before snapping. Attached are all colours.
        be more helpful if they were PDF's and not wrinkled
          • May 2020
          • 238
          You can see the white strips lines on the black and Magenta colour pattern. What seems to be to cause??
          • tsbservice
            Field tech
            • 8016
            Those samples look awful. White spots are usually bad dev/toner/paper mix or bad second transfer. As for stripes give us normal samples. Meanwhile total counter and consumables life will come useful.
              with the small JPG's ... the wrinkles.. I CAN'T SEE THE DEFECTS.. that's why we prefer to have the samples SCANNED into PDF's and then uploaded.
              white lines could come from ANY of the image formation items.
              dev.. drum... itb... laser glass.. fuser
              what have you tried? you give us VERY little information to work with here.. You are in front of the machine..we are not.
              Like the old computer saying goes " GARBAGE IN... GARBAGE OUT "
              or did you not try anything but want to pick our brains?
              what are the pages counts on the drums/dev/itb/fuser?
              have you cleaned ANYTHING?
              you say you are trained on Ricoh .... WHICH product line?
              this is really Copiers101... did you even look at the manual? do you HAVE the manual?
              a true 10yr tech should have no problem diagnosing this issue.
                • 37489
                With them having been crumpled up and the flattened back it is impossible to tell what is the result of the crumpling and what is not. Try again boy child. Also a copy of the maintenance counter portion of the SMC logging data report would be helpful as the machine may be pat due on PMs.
                  • May 2020
                  • 238
                  I've tried cleaning the LCU polygon box, changed all developers done all sorts of things still remains the same.
                    • May 2020
                    • 238
                    I recently changed developer in all colors. At times print comes out good both in solid background and then goes back. I tried figure it out for customer its seems there's no solution.
                      You cleaned the polygon mirrors? With what? That isn't recommended. LCU?
                        Did run the initial on the dev units?
                        Did you clean the patch sensors?
                        How?
                        There's always a solution .
                          • May 2020
                          • 238
                          Sent from my SM-G960U using Tapatalk[/QUOTE]
                          I Cleaned with a soft wet clothes.
                            • May 2020
                            • 238
                            If I try to initialize developer it becomes worst. I've never experienced before in all my years as a technician, though I was trained on black and white copiers, I still do repair coloured copies very well. But this is beyond me.
                              I Cleaned with a soft wet clothes.[/QUOTE]
                              read the manual it says SOFT LINT FREE -=DRY=- cloths.
                              clothes = fabric you WEAR.
                              cloths = fabric to CLEAN with
