as i describe in title, motors are not working after i press start for print job and counter list. Print jobs will work after i re-close duplex unit. But this problem will happen again when i reboot machine. Is there anyone experienced the same problem like this?
Ricoh C2003 - print job will do after re-close duplex unit
Re: Ricoh C2003 - print job will do after re-close duplex unit
Clean/check/replace the fusing thermopile unit. Located in the body of the C2003 just above the connector for the fusing unit. After removing the fusing unit two connectors and two screws to remove.Comment
Thermopile errors could also be given from faulty connections in fuser unit unplug all connectors ie thermistors etc and rear of main connector big blue one before reconnecting make sure no pins are push slightly out. Good luckRegards Mark
https://copierservices.simdif.comComment
But sometimes necessary. Decades ago I worked on Vydec word processors. 20+ boards. A board could be within design specs on its output and the board it was talking to could be within design specs on its input but you could still get random errors if one board was to of extreme of the specs and the 2nd board to the other extreme. It was pick one and replace it. If that didn't work try the other. Tag the board with a description of the error. When I got the same error on 3 or more machines I would send the board to the repair depot. Component level techs had a list of what to replace passed on reported error.Comment
