MP C2003 Can scan to WIN 10 Home but not WIN 10 Pro
  • patterson70
    • May 2010
    • 603
    Would this be resolved by a firmware upgrade? Got 2 PCs scanning to Home with no problem but getting an authentication error for 3 Pros.
    • 37533
    Re: MP C2003 Can scan to WIN 10 Home but not WIN 10 Pro
    The main difference between Win 10 Home and Win 10 Pro is that Pro can join a domain. If the Win 10 Pro is part of a domain the the C2003 have the Domain Name properly set in the interface settings, the first DNS must be the primary domain DNS and scanning must be to the computer name.
      • 30303
      Did you add user under the security tab?
      • copier tech
        • 8174
        Yes update the firmware if you're still having issues as there was a security release for this model enabling SMB 2/3 support.
        • patterson70
          • May 2010
          • 603
          There is no domain. I am trying both computer name and IP address and both are not working for 4 of 6 PCs. I did not enter any domain IPs. Maybe I should use googles domain? 8.8.8.8 and 4.4.4.4?
          • patterson70
            • May 2010
            • 603
            Not sure where the security tab is. I was in under admin and just added a user the usual way. Is there another way under a security tab of some sort?
            • patterson70
              • May 2010
              • 603
              I am working on getting the firmware. I had set SMB 1.0 in Programs.
                • 37533
                Contact a local authorized Ricoh Family Group dealer to update it for you.
                • patterson70
                  • May 2010
                  • 603
                  Thanks, I can do it and have a source for the firmware.
                  • heeks
                    • Jun 2012
                    • 19
                    You could try to switch SMB port to 445 via telnet if it's still set to 139.
                    Code:
                    msh> smb client port 445
                    and don't forget to log out otherwise changes won't be saved.
                      • 30303
                      Right. click on shared file Security tab
                      and add user
                      • patterson70
                        • May 2010
                        • 603
                        and add user
                        Could you or someone tell me where the file security tab is? Do you mean in Web Image Monitor?
                          • 30303
                          • kplow1986
                            • Nov 2013
                            • 41
                            goto "turn Windows features on or off" tick on SMB v1.0 server
                              • 37533
                              Try Windows Explorer, Right click on the folder you want to scan the files to, click on Properties.
