Ricoh MP501spf - Maintenance kit
  • dadjo
    • Jan 2018
    • 35
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP501spf - Maintenance kit
    Maintenance kits on small black and white kit are usually fuser, PTR and feed tyres / friction pads. What sort of mileage does it have?
    Hit it.
      • 37550
      I found this within 1 minute searching with Yahoo.
      Ricoh Aficio MP 301SPF Maintenance Kit - 90K, Genuine (K0019)
        wow Slim you really expect people to do their own homework!?
        • copier tech
          • 8187
          If the print quality is good simply reset or turn off that message. If you have the rollers fit them machine will run on without any issues.
          • dadjo
            • Jan 2018
            • 35
            thank you for help but that a diferent model and those parts will not fit.
            • dadjo
              • Jan 2018
              • 35
              • eccelobo
                • 113
                Just disable the PM alert setting SP5931-001 in "1".
                This machine does not have maintenance kit.
                • ThePomqueteer
                  • Sep 2016
                  • 73
                  I found this on the PSG. Looks like there is no kit, you just need to order everything individually.
                  • FrohnB
                    • Jul 2017
                    • 1919
                    If that unit has 500,000 prints or more then I would replace the fusing unit (M2814070)/ transfer roller (M2812838)/ and feed & sep rollers.
                    Maintenance kit usually refers to fuser/ trans. roll/ feed rolls, so just go into SP mode and reset those counters.
                    Omertà
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Wow has this machine already done 500k if copy quality ok just reset pm counter in service mode
                      Regards Mark
                      • dadjo
                        • Jan 2018
                        • 35
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          If jamming from cassette order the pick up roller assy the two rollers together also the cassette separation roller
                          M2812826
                          M2812520
                          Regards Mark
                          • dadjo
                            • Jan 2018
                            • 35
                            M2812826
                            M2812520
                            • dadjo
                              • Jan 2018
                              • 35
                              hello people. just to let you know that after replace of Rollers 302NM24010 , all is working ok. thank all you for help
