Ricoh mp5503 yellow disappear on printed job
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ricoh mp5503 yellow disappear on printed job
    What's the count on the color drums/developers?
    Have you tried a different ITB assembly?
    Check the yellow drum connector...make sure there are no bent pins.
    • Pixtech Frameworks
      • May 2020
      • 238
      I've not check if there's any bent pin. I check tomorrow, also I've not tried another ITB.
        • 37502
        Originally posted by Pixtech Frameworks
        This amazes me that all colours came out ok on colour pattern in service mode.
        Attached is the colour pattern.
        The yellow does look a little weak. Possibly under toned. What are the Y Vt reading in SP 3030 and how do they compare to the other colors. Fixed Charge DC Bias SP 2005 and Fixed Developer DC Bias SP 2229 may have been changed. This would also require that SP 3041-001 be set to 0. SP 3041 was moved to Factory SP mode on the Cxx03 models. Yellow transfer value may have been played as well. Speaking of played with, may also have been what my office used to call Izzified. We had a lead copier tech 15 years ago, I worked mostly on computers and dictation back then, named Izzy who liked to play around with the color Gamma settings.
        • Mark Bbb
          • Jun 2012
          • 1662
          #19
          perhaps someone was a little bit to creative in SP mode, image creation?
            • May 2020
            • 238
            #20
            I've tried auto calibration, after printing then fails when scanning. I don't why this happens.
            • Marwanalhajbi
              • Jul 2018
              • 72
              #21
              try to force yellow toner,does it give you complete ,if so, , test it,
              also try to check the laser unit perhaps there is dust on the glass that preventing lighter yellow to print out
                • May 2020
                • 238
                #22
                I've tried force toner, it gives completed.
                I check lcu polygon box and clean, still no avail.
                  • 37502
                  #23
                  Three things that can usually cause the scan to fail; dirty optics, dirty ID sensor or depleted development unit. You may need to replace the development unit.
                  • johnnyquest
                    • Feb 2020
                    • 16
                    #24
                    take the endcap off the rear of the pcu. bend up the two contacts and reassemble. yellow will jump off the page. did you forget to reinstall? i have.....
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      #25
                      I've done auto calibration, copy and printing. But when scanning it fails and tell me to start process again. Attached are original and photocopy for more clarification.
                      OK if its only on copy clean all optics under glass remove laser unit very carefully clean then start again with acc
                      Regards Mark
                        • May 2020
                        • 238
                        #26
                        I've found solutions guys.
                        one of the gears at the developer unit is broken, also the cover too.
                        I replaced all and everything seems to work fine now. Attached are the broken accessories.
                        Thanks for the contributions, deeply grateful.
                        • makeacopy100
                          • Oct 2019
                          • 24
                          #27
                          Hi All,
                          A customer ricoh mpc5503 yellow appears when colour pattern is printed, but printed or photocopy jobs, yellow disappears completely.
                          For example a job that has Red in it only Magenta appears. I have tried all I could know changing developer, opc drum, OEM toner, it seems not to work.
                          Does anyone knows what the issue is??
                          try replacing drum and developer as the drum surface is too weak to originate pixels on it, the test pattern yield more charging than copy.
                          • mikadonovan
                            • May 2008
                            • 2931
                            #28
                            Read the post right before yours. He already found the problem.
                            NEVER ASSUME ANYTHING
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              #29
                              Well done I thought you already replaced the developer oem would of been complete unit
                              Well done
                              Regards Mark
                                • May 2020
                                • 238
                                #30
                                I didn't buy complete unit. OEM Developer only bought from Amazon, I had to replace other parts from damaged developer unit.
                                Its all fine now. Thanks.
