Ricoh mp201
  • Ricoh5150
    • Mar 2019
    • 6
    Ricoh mp201
    trying to make multiple copies it'll do one page and then beep and won't continue to print out the others.
    Re: Ricoh mp201
    paper type/size mismatch
    • FrohnB
      • Jul 2017
      • 1919
      Re: Ricoh mp201
      Are you sending a print job, or making a set of copies?
      If it's a print job....then it's probably a size/type mismatch. Make sure that your tray is set to plain paper (or whatever paper type you're printing on) and correct size, and make sure your computer settings match.
      Haven't heard of that problem when copying.....unless number of copies isn't selected.....or if someone is using "sample copy"...which I'm not sure if that series had that function.
      Omertà
      • anothertech
        • 1771
        Re: Ricoh mp201
        Read the messages on the screen, the machine will tell you what it needs, you've just got to look to see what it's trying to tell you.
          • 37652
          Re: Ricoh mp201
          I have seen that problem with flaky door switches. Vibration from somewhere causes the machine to momentarily detect door open as the paper exits..
          • Pulsara
            Technical Manager
            • Aug 2015
            • 27
            Re: Ricoh mp201
            Question doesn't mention whether there are any indications like paper jam sign, after the first copy came. Or just take another copy by pressing start key, without open/close any cover. If so, problem with casette paper end sensor. Contact plates inside the sensor lost its contact repeatedly by oxidization.
            • Mark Bbb
              • Jun 2012
              • 1662
              Re: Ricoh mp201
              The older models had a sample copy function, when you want to print the rest, you first need to push the x button...
              als you can limit the copy quantity in the user mode (also with old models).
              Check this first.
              • Ricoh5150
                • Mar 2019
                • 6
                Re: Ricoh mp201
                Exactly.. When I showed up the paper out sensor would blink between copies.
                • RustySprocket
                  • Mar 2020
                  • 19
                  Re: Ricoh mp201
                  Ive seen this once, maybe twice. Paper end sensor needed replaced.
