Scan to email absolutely not working
  • RustySprocket
    • Mar 2020
    • 19
    #16
    Re: Scan to email absolutely not working
    It looks like we found the problem. SSL 3.0 must be enabled in the WIM. Use SSL secure connection and port 465. Those settings allowed the email to send from the office Ricoh. Now to try it on the customers Ricoh.
    • sandmanmac
      • 3981
      #17
      My bad for assuming that you had entered the correct settings in the first place.
      Glad you found a working solution, however, SSL3.0 does not necessarily need to be enabled, but of course "use secured connection (SSL)" needs to be selected, and port 465 (although I believe port 587 may work as well).
      However,
      getting back to my original suggestion, 'enable less secure apps' is a bad idea.
      2FA / app passwords are the far better option.
      Suit yourself...
      • kayjaig
        • 144
        #18
        However, [/B]getting back to my original suggestion, 'enable less secure apps' is a bad idea.
        Suit yourself...[/QUOTE]
        Thanks for your suggestions.
        By the way. How do you apply 2 Factor Authentication App in the unit?
          • 37490
          #19
          Suit yourself...
          By the way. How do you apply 2 Factor Authentication App in the unit?[/QUOTE]
          BTW Google is in the process of eliminating 'enable less secure apps.' Not sure of the cut off date but if you are not a Google Apps or Google Suite user and can setup one of the other Port 25 options available to them soon you will not be able to use older MFP that do not support TLS.
          • RustySprocket
            • Mar 2020
            • 19
            #20
            However,
            Suit yourself...
            I dont think the snarkiness was necessary, thanks for your suggestions.
              how was Sand being 'snarky'?
                • 37490
                #22
                That comes very close to being rude to a senior member. I would advise you avoid such comments in the future or run the risk of getting Red Carded and reported.
                  wow brother you handled that with calm...
                  how do you do it?
                  do you type out all the rage ... and then erase and start over?
                  am in awe Sir.
                  I would have torn him a new hole.
                  • sandmanmac
                    • 3981
                    #24
                    You don't
                    You enable it in the Google account, and then use the app password in the email section when setting up scan to email
                    Not sure about that take....but whatever, man.
                    I'll be sure not to provide you any more free advice for fear of hurting your feelings
                    blocked!
                    • sandmanmac
                      • 3981
                      #25
                      how do you do it?
                      am in awe Sir.
                      You were very quick to see that initial reply (that, yes, has since been deleted).
                      The sun is shining today and I personally thought it was a touch harsh
                        A True Gentleman.. again I commend you on your diplomacy!
                        I tried quoting that reply ... went white screen no quote.. you must have been in the process of editing/deleting it.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          #27
                          Al those lang toes, my lord
                          Come'on you guys..., be a little more friendly to one another, YOLO !!!!!!!
                          Life is already difficult enough, so forgive each other, and pick up the wire here.
                          Damn!
