Alternative to lubricants indicated for ricoh pro8120s
  • diego_akd2009
    • May 2011
    • 79
    Good morning, I would like to know from the most experienced of the group if they have any alternative to the official lubricants recommended by ricoh, or the details of the characteristics that these should have, specifically
    FLUOTRIBO MG Grease
    Grease Barrierta - S552R
    Silicone Grease G-501
    We tested with lubricants used in desktop printers and smaller printer fusers but they liquefy very quickly, in fact we had many 720-40 and j114 errors and we have solved it with very thorough lubrication of the stapler mechanisms, but it does not stop liquefying soon, thanks
  • anothertech
    • 1771
    Re: Alternative to lubricants indicated for ricoh pro8120s
    I use 3-in-One oil, we also use typewriter oil. I've heard sewing machine oil works good too. The finiser rails get gummed up, they really need to be cleaned thoroughly first and then lightly lubed.
    • kleankopy
      • Feb 2016
      • 115
      We use 41amJdaoP-L._AC_.jpg on all our SR 5000 and it has been a world of difference with jamming. One of my techs tried a ricoh grease and it caused all kinds of jamming.
      Tried other 3 in 1 oil but this worked alot better on all the rails. Make sure you clean first with alcohol if their is any dried grease.
      • Notrons
        • Apr 2016
        • 71
        I use Super Lube for fuser bearings and gears. 3-in-one works great for everything else.
          • 37532
          Try Super Lube multipurpose grease with PTFE. Check your local hardware stores or order from Home Depot. https://www.homedepot.com/p/Super-Lu...-202932687-_-N
          • kleankopy
            • Feb 2016
            • 115
            We tried all those but since we switched to the triflow we get no more calls on finisher jams. We cleaned and re lube every service call or pm and our finisher jam calls have stopped.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
                • 37532
                I use electrical contact cleaner. Get it at local hardware stores.
                • mikadonovan
                  • May 2008
                  • 2931
                  I use Lubriplate hi-temp grease for fuser bushings and such, and spot lubing I use 5w30 motor oil in a small oiler, which can also be used in high temperature areas.
                  NEVER ASSUME ANYTHING
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    At one time, we used Marvel Mystery Oil.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      X2 on the Lubriplate. Good stuff.
                      • JaysOnTheEDGE
                        • 61
                        What exactly are you lubricating in the finisher ? I was just curious.
                        • JaysOnTheEDGE
                          • 61
                          FLUOTRIBO MG Grease
                          You can use Chemours Krytox XHT-S as its fluorinated in place of the Fluotribo MG and Barietta image supply sells it or you find it on amazon the Silicone grease i just used the ricoh part i order a tube 5 years ago and its still got a lot left I don't use it very often.
                          • Eremite
                            • Mar 2019
                            • 12
                            Any PFPE oil is suitable.
                            But I using fluotribo.
