"toner cartridge not set cyan"
  • aficio63
    • Jun 2014
    • 36
    Greetings...I have a MP C3004exss with this message. I have tried:
    a different cartridge
    checked all connections in controller
    replaced:
    rfid pcb
    bcu pcb
    I/O pcb
    HDD format
    Any help would be great
  • Notrons
    • Apr 2016
    • 69
    Re: "toner cartridge not set cyan"
    Check the tension spring that holds the toner bottle in place. I have had those pop lose a few times on those models.
    • Oze
      Ricoh Fanboy
      • 1663
      Replace the cyan toner supply unit.
      D1493270
      TONER HOPPER:TONER SU
      PPLY:C:ASS'Y
      The auger has twisted up on itself.
      You may also need to replace the Cyan dev assy at the same time.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        D1493270
        PPLY:C:ASS'Y
        That usually replace toner. not cartridge set error properly
        Regards Mark
        • Oze
          Ricoh Fanboy
          • 1663
          Well he's already done the rfid board AND the IOB.
          Toner supply assy is pretty cheap to take a gamble on.
          • fshead
            • 2356
            I had one where it would not stay in unless held and would not accept cartridge and gave me cartridge not set even if i held it in and
            bypassed interlock.
            After mucking thru the chip was in backwards.
            always dot in if you look at cartridge how chip is installed..
            • aficio63
              • Jun 2014
              • 36
              D1493270
              PPLY:C:ASS'Y
              Forgot to list these items on the laundry list of things done.
              I did replace these 2 items as well.
              • aficio63
                • Jun 2014
                • 36
                bypassed interlock.
                Yes, I cheated the interlock and held the bottle in...no change.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Just asking back to the start you sure you have tried new oem toner for this model
                  Regards Mark
