PASSWORD
  • Jama
    • Jul 2020
    • 49
    [Misc] PASSWORD
    Have new ricoh mp2014ad installed, everything ok but when trying to set up scanner...that is scan to folder, the password admin..blank, supervisor , password ..password fails to login, could this be issue to reset factory defaults or which other passwords can be entered? any assistance will be appreciated. thanks in advance.
  • copier tech
    • 8133
    Re: PASSWORD
    [ATTACH=CONFIG]47101[/ATTACH]
    Is this a brand new machine you are installing or used/2nd hand?
    • Jama
      • Jul 2020
      • 49
      Re: PASSWORD
      This is a brand new machine 0 mileage, all default pwds fails including supervisor
        • 37422
        Re: PASSWORD
        Talk to the person who first turned it on.
        • copier tech
          • 8133
          Re: PASSWORD
          Try:
          admin
          password
          • Jama
            • Jul 2020
            • 49
            Re: PASSWORD
            Try:
            admin
            password
            Thanks, I will try tomorrow. will update osn same.
            • copier tech
              • 8133
              Re: PASSWORD
              But as slim said whoever first powered on the machine out of the box would have been prompted to set the password (or leave blank as should be done)
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Re: PASSWORD
                If you can't find out what password was used you will have to reset in factory mode sp 58xx x6
                Most common is admin with blank password or admin admin
                Regards Mark
