Ricoh mp c5502 color pattern (black fade)
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi All,
    I got a customer 5502, black section of color pattern seems to fade, on impression (CYMK) black seems to be not stable. Attached its the colour pattern sample.
    Any help.
    • 37386
    Re: Ricoh mp c5502 color pattern (black fade)
    You may have some dust or toner haze on the K laser shield glass. Try using the shield glass cleaning stick that should be mounted inside the front door.
      • May 2020
      • 238
      I've done a thousand times, problem still remains.
      Any other idea??
      • copier tech
        • 8131
        Originally posted by Pixtech Frameworks
        Hi All,
        Any help.
        What's the black dev PM life on?
          • May 2020
          • 238
          Developer was changed not quite long with OEM developer.
            • 37386
            First the term OEM is used by after market suppliers to make you think you are buying a good product. It only means meets the basic recipe as to ingredients. It does not mean the same quality and consistency of Genuine. Very seldom do after market product receive the same testing and quality control as Genuine. There is only one after market supplier that I know whose developers and toners are as good as Ricoh and their prices are roughly the same if not higher. So is the developer you used merely OEM or is it trademark registered Genuine Ricoh?
            That being said, a closer examination of the test pattern reveals that your problem is most likely not in the K PCDU unless all four PCDUs have exactly the same problem. Look at where the 4 vertical color bars cross the 4 horizontal bars. The same pattern of fading can be seen in all 4 colors. Assuming that the test sheet was fed narrow edge first that would indicate either the ITB or the PTR.
            • tsbservice
              Field tech
              • 7986
              This test chart isn't good enough example. Print 4 pages A3(Ledger) CMYK solid color at 50% fill and post.
              Your black looks very pale almost like old developer but there're many other things involved.
                • May 2020
                • 238
                Hey Slimslob
                I think the PTR would be the cause, I could remember a customer had same issues on c3002, I had to clean the PTR with soft wet cloth and straighten all the little iron around it worked fine.
                May I should do same thing or order new part PTR assy.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Hey Slimslob
                  I dont think it would be the ptr other wise it would happen on all colours
                  Regards Mark
                    • 37386
                    Take a closer look at where the horizontal and vertical color bars cross. It does affect all colors.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      I can only see fault with black I think it would be more likely pcu or dev area BUT I could be wrong
                      Regards Mark
                        • 37386
                        Look at the lower right hand portion of the PDF. The fade pattern crosses all 4 colors. Not as bad as the K but still there. M is the next most noticeable. C very little but still there.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Best to wait for the outcome I would place a 20p bet it's not ptr.
                          Stay safe slimslob
                          Regards Mark
                          • tsbservice
                            Field tech
                            • 7986
                            May be 2 different problems as well.
                              • May 2020
                              • 238
                              Am quite sure its the PTR.
                              I've the part for the customer, waiting for delivery.
