MP4000B
  • +ve charge
    • May 2008
    • 87
    MP4000B
    Hi... Can someone pls let me know what the interchangeable parts are for the MP4000B. Can all maintenance items (drum, dev, blades, heater, ect ect...) replaced on the MP4500 be fitted onto this machine?
    Yr response will be appreciated. thanks & regards
  • TonerMunkeh
    Professional Moron
    • 3865
    Okay, in order:
    Drum - no.
    Drum Cleaning Blade - no.
    Charge Roller - yes.
    Charge Roller Cleaning Roller - yes.
    Hot Roller - no.
    Pressure Roller - no.
    Web - no.
    Developer - yes.
    As for the fusing lamps I've not had reason to take one of these fusers to bits that severly yet. Parts catalogue will tell you.
    Hit it.
    • rthonpm
      • Aug 2007
      • 2847
      You can actually use the drum for the 4000 in the older machines (at least to the 2035), though the fit is a little tight at first, but it will fit. Charge roller, cleaning blade, transfer belt, developer (B2969640) are all common with the 4500.
