SC672-Mpc3504
  • tavorh
    • Sep 2016
    • 25
    SC672-Mpc3504
    Hello,
    I have a problem with machine Mpc3504, because it keeps showing me that there is a problem with a code sc672-00.
    Do you have any suggestion on how to fix this problem?
  • KeviM
    • Oct 2019
    • 324
    Re: SC672-Mpc3504
    Hello
    I haven't worked with this particular model but from what I have experienced with multi-function black and white models is that SC 672 is normally a hard drive fault. Change the hard drive and test. If you still have a problem change the controller and test.
    • FrohnB
      • Jul 2017
      • 1919
      Re: SC672-Mpc3504
      Usually SC672-00 is going to be the Controller board.
      Omertà
      • copier tech
        • 8141
        Re: SC672-Mpc3504
        Originally posted by tavorh
        Hello,
        Try updating the firmware if this fails replace the controller.
          • 37452
          Re: SC672-Mpc3504
          There should be a dash number after the SC672 like SC672-11. They are all covered in the service manual. On the metis a common cause was the USB cable between the Controller and the Operation panel. Common enough that Ricoh-USA put out a service bulletin on it. Try disconnecting and reconnecting the USB cable at both ends.
            • 37452
            Re: SC672-Mpc3504
            Originally posted by KeviM
            Hello
            Controller start up error on C3504. HDD errors are in the 800s.
            • MIKON
              • Jul 2015
              • 186
              Re: SC672-Mpc3504
              If there is a line filter with network filter try using it.I spoke to Lee at Hytec and he suggested it.That is if the controller hasn't puked....
              • KeviM
                • Oct 2019
                • 324
                Re: SC672-Mpc3504
                Thanks slim. Wasn't certain if it was the same as the black and white models
