SP5810DN
  • Pulsara
    Technical Manager
    • Aug 2015
    • 27
    SP5810DN
    Hi.. Until now I have only had experience with Ricoh MFP's. My company has just purchased some SP5810DN used units for rent (as we are desperately trying to keep afloat in this situation). My problem is that i'm unable to go past logging in the user & password using the standard methods (even supervisor) and as such unable to enter our IP address range. I've also tried reading the service manual (which i downloaded) to get an idea of what to attempt but have come up blank. I dont want to try any clearing of memory until I get some advice from you gentlemen who know. I will surely appreciate any help that is offered. Thanking you in advance.
    Re: SP5810DN
    if you can locate the birth cert for the unit.. wouldn't recommend doing an all clear.. can you print out SMC report?
    • Pulsara
      Technical Manager
      • Aug 2015
      • 27
      Re: SP5810DN
      Thank you for your quick response.. If by Birth Certificate you mean the "Factory setting Data Sheet", it is not available but we did print out the SMC report which is with us. Pls advice.
      • mikadonovan
        • May 2008
        • 2931
        Re: SP5810DN
        Might be a 5310.
        NEVER ASSUME ANYTHING
        • sandmanmac
          • 3990
          Re: SP5810DN
          Whatever the correct model number is....
          Just liked the MFP's, you have to enter factory mode in order to reset the Supervisor/administrator passwords (although the access procedure is different), and I hope that no one posts that information here...in a public forum
            • 37652
            Re: SP5810DN
            If you can get into SP mode, see if SP 5828 Network settings is available. If it is you should be able to set the IP address and other network settings there. If nothing else it will at least show you the current address.
            • copier tech
              • 8236
              Re: SP5810DN
              Double check the model number SP5810 does not exist it sounds more like a service SP mode!?
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Re: SP5810DN
                As others have stated.
                You'll have to clear the UCS and address book settings in Factory SP mode.
                That'll reset the machine to allow you to set default passwords.
                • Pulsara
                  Technical Manager
                  • Aug 2015
                  • 27
                  Re:SP5310DN
                  My Apologies to all of you for the typo. The model is SP5310DN...
                  Whilst thanking you for your advice i will retry based on the responses posted. Will keep you informed on progress. Thanks Again & Please Stay Safe!!
                  • Pulsara
                    Technical Manager
                    • Aug 2015
                    • 27
                    Re: SP5810DN
                    Thanks again for your encouraged advices. I managed to initialize/reset address book data by using Factory SP. Now everything is fine.
                      Re: SP5810DN
                      good job brother!
