MP6000 black screen, functional no codes
  • Toner Boy
    • Aug 2007
    • 365
    Inverter PCB or LCD ? Temp enabled ops with MP8001 panel assembly, components are different
    • 37494
    Re: MP6000 black screen, functional no codes
    Most likely the inverter. You can check the output with a multi-meter.
    • zoor
      • Jul 2019
      • 26
      If the copier works, in most cases the LCD backlight burns out. Replace the CCFL lamp is an inexpensive option (220mm x 2mm). You will need to remove the LCD board and disassemble it. Ricoh uses a warm light CCFL lamp, you will probably get a cold light CCFL lamp, works anyway .
      • Codex
        • May 2008
        • 704
        If you have an old Mpc4500 or Mpc2500 around, you can use the panel and the panel control board, done this many times and it works...
        Inviato dal mio SM-G935F utilizzando Tapatalk
        Memento Audere Semper
        • copywhisperer
          • 8
          I have solved this issue by replacing LCD this morning. The LCD had been backordered since Oct. 8th & finally arrived yesterday. I had temporary used MP8001 panel to make the M/C work at least & the customer was generous enough to live with it. The customer seems to prefer MP8001 panel instead of MP6000 because MP6000 is B/W screen VS MP8001 is color screen.
          • Toner Boy
            • Aug 2007
            • 365
            FIXED - with some patience and LM085YB1T01
            $20.94 total cost: CCFL warehouse
            Thanks for all who chimed in. May look a little different (cold vs warm lamp as zoor noted) but works for me. Lamp was burnt to the point of breakage.
            Hold back on the caffeine when playing with this thing...
