MPC3004 please wait
  • Keegan Chetty
    • May 2015
    • 113
    MPC3004 please wait
    Hi All
    Please could I have some assistance, I have an MPC3004 which comes up with please wait, there are no errors, no SC codes, the please wait doesn't go away and there is no "check status" option on the bottom left corner to go to SP mode.
    I've tried replacing the HDD and formatting but it still does the same thing. Is there any way to reset this machine without replacing the controller? I think the machine had software like papercut previously.
    Thank you
  • Polarbear
    • Feb 2012
    • 1070
    Re: MPC3004 please wait
    Originally posted by Keegan Chetty
    Hi All
    Thank you
    Hi
    If there was papercut previously installed, the device can take up to 5 minutes or more to get to any form of ready state, as the software loads in the background, the device is also trying to poll the ip address that was configured as part of the papercut install.
    Once you get to the ready state, navigate to administration in user tools and look for extended features. You can disable papercut in that menu.
    Then the device startup time will return to normal.
    Press the GREEN button!!
    • TonerMunkeh
      Professional Moron
      • 3865
      Might not be the controller, could be the ops panel mainboard. Try doing a factory reset on it, see if that wakes it up. Are you getting any noise out of the engine when the machine starts?
      Hit it.
      • Keegan Chetty
        • May 2015
        • 113
        Originally posted by Polarbear
        Hi
        Thanks I did try that, the machine was left on for over an hour and nothing changed.
        • Keegan Chetty
          • May 2015
          • 113
          I would have but I cannot get into SP mode as the check status option doesn't show up
          • Keegan Chetty
            • May 2015
            • 113
            No noises at all, everything sounds normal
            • Polarbear
              • Feb 2012
              • 1070
              Have you got another op panel you can try?
              • TonerMunkeh
                Professional Moron
                • 3865
                Switch it off at the mains, press and hold EX1 and EX3, switch it on, when it shows the blue horizon screen go to EX1 and EX2. That's factory reset mode.
                Hit it.
                • Keegan Chetty
                  • May 2015
                  • 113
                  I do have a few machines here will try that thanks
                  • Keegan Chetty
                    • May 2015
                    • 113
                    Tried that as well no luck
                    • luca72
                      • Oct 2017
                      • 1678
                      Hi All
                      Thank you
                      hi, try the following:
                      1) try to turn on the mc without hdd, what happens?
                      2) is there the fax card? try to remove it momentarily
                      3) try to physically disconnect the connectors of the various cards (controller, iob, etc.) and reconnect them, it has happened to me quite a few times that it worked
                      *if it works, and if you don't use them, disable the java applications at startup
                      "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                      • Keegan Chetty
                        • May 2015
                        • 113
                        Tried without HDD it still does the exact same thing, no fax card and tried disconnecting cables and putting them back as well as the ram.
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          Argh the panel is probably in quick startup mode. New mainboard time unfortunately.
                          Hit it.
                            • 36854
                            If the android OS of the Smart Operation Panel is failing to start up, that is the only solution.
                            It could also be a bad USB cable between the controller and the panel. If that happens, the Op Panel is "waiting" for communication from the controller.
                            • luca72
                              • Oct 2017
                              • 1678
                              Hi All
                              Thank you
                              ok, try to start the mc using a sd-card equipped with only "system/copy" firmware, in romdata folder, and see what happenes...in any case, be patient to wait when you do the various tests, otherwise you risk getting screwed....smoke one cigarette..LOL
