Ricoh mp c307, vertical spot on sheet
  • mauropsx
    • Sep 2020
    • 5
    Dear good evening, I hope you are very well. I need if you can guide me I have a RICOH mp c307 with a vertical stain, which is repeated when I take more prints and copies (see photo). clean and discard imaging units, fuser unit, clean the lenses of the two lasers. the transfer band is changed 3 months ago.
    I listen to suggestions.
    Best regards
    • 37532
    Re: Ricoh mp c307, vertical spot on sheet
    By vertical do you mean parallel to or perpendicular to the direction of paper travel?
    • mauropsx
      • Sep 2020
      • 5
      hello, by vertical I mean perpendicular (white spot present along the A4 sheet). This spot repeats as a pattern in subsequent prints.
      • sandmanmac
        • 3981
        Why would you not print out and upload an actual colour test page? That is how one troubleshoots which colour(s) are the possible cause of the issue. It is VERY difficult to do that with a photo!
        • Polarbear
          • Feb 2012
          • 1070
          [ATTACH=CONFIG]47189[/ATTACH]
          Best regards
          Hi
          Are you talking about the white lines on your image.
          This looks like clots in one of your colour dev units. Set the machine for single colour mode, and reprint, so that you can see which unit is making missing colour in those areas.
          Press the GREEN button!!
          • sandmanmac
            • 3981
            Originally posted by Polarbear
            Hi
            Agreed. I would just say that to me, the simpler solution is to print the colour test page which will show each of the colours that may be causing problems.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Best regards
              If you have cleaned under laser it will be one of the drum cyan or yellow looks to me as you can see red at the bottom of the page
              Regards Mark
                • 37532
                It looks to me like all colors or colours are affected. The lines do extend through the red background of the text at the bottom.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Check if the PTR has any score marks in it.
                  Hit it.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    That would be from the other colours in that shad of red best if he does single colour copy
                    Regards Mark
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Good one I've had that +1
                      Regards Mark
