Black square when scanning only
  • zackrch
    • Jan 2018
    • 8
    [Misc] Black square when scanning only
    Hello, Has anyone ever had a problem when scanning there will be a black box in the middle of the paper?Using konica model B/W 458E.This is happen only if use for scan other than that nothing wrong.I have reconnect the ccd cable,prcb cable and all other cable that connect to the scanner unit and also i already upgrade latest firmware.
    • 37491
    Re: Black square when scanning only
    Might be a memory or HDD error in the portion use for the scanning function.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      • zackrch
        • Jan 2018
        • 8
        Thank you all, right now i do physical format for hdd, i will update later.
