RICOH MP C3503 White streaks after installing new drum + dev
  • Like1mS
    • Jun 2018
    • 23
    [Misc] RICOH MP C3503 White streaks after installing new drum + dev
    Hello,
    We had a problem with MP C3503 machine from a client, white streaks on page exactly as in the pictures. It was solved by swapping the PCDU from a working machine with low counter.
    For donor machine we ordered and replaced new pcu + dev. And misteriously the same happened. Even though before swapping drums only one of them was problematic.
    I cant wrap it up, what could cause this on a perfectly fine machine whitch had no problems, plus new parts installed. Maybe someone has seen this before and can help ?
    Any suggestion appreciated.
    P.S The page comes out long edge.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: RICOH MP C3503 White streaks after installing new drum + dev
    Could be that by taking out this pcdu some toner upon the pcdu dropped on the toner shield glas . Clean it. Solved?
    • davel
      • Oct 2011
      • 1108
      Looks more like short edge feed to me, as Mark said, clean laser glass then check dev roller.
      • Like1mS
        • Jun 2018
        • 23
        Thank you for your time Mark. As i mentioned before the page comes out long edge if there would be toner on glass the streak would go long to long edge, and now its short to short. I tried cleaning as you suggested nothing changed.
        • Like1mS
          • Jun 2018
          • 23
          Checked developer roller. Its brand new, no visible streaks. I dont understand how can streak like this long to long edge even occur. I understand short to short edge, toner on glass or something stuck in developer, but this, first time for me. Cant understand how its happening.
          • Like1mS
            • Jun 2018
            • 23
            The page comes out long edge not short.
            • dave w
              • Jun 2015
              • 230
              Was the PCU rear cover transferred over from old pcu?
              • Mark Bbb
                • Jun 2012
                • 1662
                Check the connector from the wire from the TD sensor.
                I've had the same problem once because it was not deep enough plugged!
                • Like1mS
                  • Jun 2018
                  • 23
                  Thank you Dave, right on the spot. Thats exactly what happened, person replacing the drum lost or threw out the back cover, and as i installed the new once didnt have the piece.
                  Problem solved. Thanks again guys for quick responses
                  • dave w
                    • Jun 2015
                    • 230
                    I had a feeling that may be the problem as that same thing happened to me
                    Dave
