Ricoh mp2501 panel hanging
  • Jama
    • Jul 2020
    • 49
    [Misc] Ricoh mp2501 panel hanging
    Have ricoh mp2501sp, machines comes ready from on, but panel hangs, nothing can be commanded from control panel. Anything to check?
  • copier tech
    • 8174
    Re: Ricoh mp2501 panel hanging
    If the machine can print & the hard keys work sounds like you have a failing touch pad so either clean or replace it.
    We have a few issues like this usually down to customers "sanitising" the screen.
      check the cables that go from panel to boards.. pull n reconnect
      what have you done?
      any error codes ?
      what happened before issue showed up?
      • Jama
        • Jul 2020
        • 49
        what have you done?
        any error codes ?
        The machine was just working, the panel just from on point hangs without doing, customer was the one who realized. No error code.
        Any procedure to calibrate touch screen ?
        • Jama
          • Jul 2020
          • 49
          what have you done?
          any error codes ?
            it's in the service manual ..you shouldn't be working on these WITHOUT a manual.
            to request a manual put your request in this forum per forum rules ---> https://www.copytechnet.com/forums/s...nual-requests/
              • 37532
              • Jama
                • Jul 2020
                • 49
                Noted, will try this and update on same, thanks in advance ..
                • makeacopy100
                  • Oct 2019
                  • 24
                  first check panel on other machine if its ok than go for hard disk
                  • Polarbear
                    • Feb 2012
                    • 1070
                    So the hard buttons work?
                    Could be the touch glass on top of the LCD. We had some failures, due to customers spraying sanitiser on the machines because of COVID.
                    We ended up replacing some (which we could not prove the cause) and billing others where you could clearly see the sticky goo on the glass.
                    Try doing the calibration, as other posters suggested.
                    Press the GREEN button!!
                      • 37532
                      Those that want to sanitize their copiers should be told that the most effective sanitizer is ethyl alcohol diluted with water only to no lower than 70% alcohol.
                      • Gift
                        • Mar 2011
                        • 2459
                        Better use hairspray and a lighter
                          • 37532
                          Originally posted by gift
                          better use hairspray and a lighter
                          are you saying that you drink hair spray????
                          • tsbservice
                            Field tech
                            • 8020
                            Slim I think he tried to joke...well bad attempt.
                              • 37532
                              No he was being an asshole.
