Ricoh mpc2051
  • Pixtech Frameworks
    • May 2020
    • 238
    Ricoh mpc2051
    Hi everyone,
    I got a customer c2051, it has this yellow straight lines at the center of the paper both copy or print, at times yellow, cyan or magenta.
    Does anyone has the idea of what could be the problem.
    See attached for further clarification.
    Thanks.
  • MIGUELMARCHENA
    • Feb 2018
    • 195
    Re: Ricoh mpc2051
    Cleaning blade on transfer
    Enviado desde mi H3321 mediante Tapatalk
      Re: Ricoh mpc2051
      Originally posted by Pixtech Frameworks
      Hi everyone,
      Thanks.
      transfer belt cleaning unit
      Color Copiers 101
        • May 2020
        • 238
        Re: Ricoh mpc2051
        Thanks everyone for the contributions.
        • skinnyb
          • Jul 2008
          • 291
          Re: Ricoh mpc2051
          Color Copiers 101
          Yep. Real easy to replace too. If the belt isn't screwed up as well. I have rarely to never had a ITB cleaning unit fail on one of those.
          Sent from my LM-V405 using Tapatalk
            Re: Ricoh mpc2051
            well since we didn't page counts or anything I was just pissing in the wind with my thoughts
              • 37550
              Re: Ricoh mpc2051
              Without PM counters to give us the facts, those samples are just skid marks IMHO.
                Re: Ricoh mpc2051
                oh no did someone just shit his BVD's?
                • copier tech
                  • 8187
                  Re: Ricoh mpc2051
                  Hi everyone,
                  Thanks.
                  Open the right door you can view the transfer belt & see this line on the belt?
                  If this is a low use machine remove the cleaning unit, empty the waste toner & clean the blade & reassemble this will resolve the issue temporarily until you can replace the cleaning unit.
                  You access this part from the left side on the machine (2 screws cover drops down)
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Re: Ricoh mpc2051
                    +1
                    Regards Mark
                      • May 2020
                      • 238
                      Re: Ricoh mpc2051
                      Ok, I'll do that for the mean time till the cleaning blade of the ITB is changed.
                      • fshead
                        • 2376
                        Re: Ricoh mpc2051
                        i ve seen a lot of times small debris or small piece of paper up against the itb blade.
                        just pull it out and check,and clean
                        • tsbservice
                          Field tech
                          • 8028
                          Re: Ricoh mpc2051
                          If he didn't do that already(was mentioned from several members) he just doesn't deserve advices anymore.
