banding ricoh 5100
  • Imprestik
    • Aug 2012
    • 296
    Re: banding ricoh 5100
    Originally posted by mga
    Same same lines in all colours I would check ptr assy and wax bar in there
    There is no wax bar in the PTR assembly on the 5100's, only a roller and discharge plate
    Since you have have the exact same bands across all channels it has to be transfer related.
    It's has to be either,
    The belt has the same marks as your bands so your in for a ITB rebuild so a new belt, 4 x image transfer rollers and a bias roller. You will also want to do a cleaning unit cause I'm sure the blades will scratch the new belt
    or
    You have contamination on your cleaning unit blades which are not cleaning the belt properly so you may need to rebuild your cleaning unit only
    That's what I would be checking
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      or
      Sorry my mistake I see more 52xx series forgot not on 51xx series
      Regards Mark
