MP C6501 HDD Replacement
  • sandmanmac
    • 3983
    #16
    Re: MP C6501 HDD Replacement
    Originally posted by anothertech
    You do not need to order the drives from Ricoh. I have used two 250GB drives off the shelf plenty of times.
    Agreed!
    They simply need to be 2 identical units (brand/size/ speed).
    You cannot mix and match
      Originally posted by sandmanmac
      Agreed!
      and they shouldn't be pre-formatted .. clean IDENTICAL Drives.
        • 37553
        #18
        If you try all the recommendations for using 2 identical 160GB drives and it works, fine. If it goes not work it could be that instead of treating them as 2 striped 8 bit drives, Ricoh treats them as one single 16 bit drive. In order to do so there is a code sequence placed on absolute sector 0 that identifies whether the drive is the upper 8 bits or the lower.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          Agreed also once in machine will need format in service mode also stamp from rom
          Regards Mark
