MPC306 Touch panel calibration
  • GeorgeBest
    • Jul 2009
    • 520
    Hi,
    does anyone know how to enter the "touch panel calibration mode". on this machine?
    thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MPC306 Touch panel calibration
    Panel SP mode
    Hit it.
    • GeorgeBest
      • Jul 2009
      • 520
      And how to enter?
      as in the old machines , Clear, 1993, 5x C, 1 ??
      Originally posted by TonerMunkeh
      Panel SP mode
      • FrohnB
        • Jul 2017
        • 1919
        Same as newer Service Mode entry code except you end it with #,#, "C" <--Hold down C for like 5 seconds, and when you release it, it will go to "screen Service mode".
        Go down to "Screen Device settings" and then at the bottom of that page will be "Panel Self Check".....touch that and it will bring you to a screen to let you choose between calibration, LED test, etc..
        Omertà
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Hope this helps
          Regards Mark
            • 37375
            Originally posted by mga
            Hope this helps
            Might not work for getting into touch calibration if you have to use the touch screen.
            • copier tech
              • 8131
              Originally posted by GeorgeBest
              Hi,
              thanks in advance
              Many users are been drenching their panels in all sorts of cleaners trying to 'sanitise' after each use.
              Basically any calibration wont work, this is designed for after fitting a new panel.
              I have been billing my clients for 'accidental damage'
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Hope this help
                Regards Mark
                  • 37375
                  One thing to try is a power cycle clear. It shouldn't hurt and it may help. Turn the main power OFF and unplug the power supply cord. Push the main power switch ON again to discharge the residual charge. Plug the power cord back in. If the Touch Panel Calibration is off because the memory used to store the setting has been corrupted by a power surge or a static discharge this might clear it.
                  • JayPaul
                    • Oct 2012
                    • 305
                    • copier tech
                      • 8131
                      Thanks for the info. Here's a breakdown of the SOP.
                      Item 3 should be all you need unless they have really drenched it! D1961503
                      Smart_Operation_Panel.pdf
                      • JayPaul
                        • Oct 2012
                        • 305
                        • copier tech
                          • 8131
                          Yes this is from the TDC on the MP C306.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            The touch screen will away be available if not in parts manual check for lasted on my ricoh don't forget tdc2 only gets updated with new patch and the latest manual may not be on there
                            Regards Mark
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              Mpc2004 to 6004 smart panel parts from tdc not in machine parts has its own manual
                              Regards Mark
