C5100Pro
  • leonardcahill
    • Nov 2019
    • 23
    C5100Pro
    Can anyone tell me what caused all the little bumps on my transfer belt. We just changed the belt cleaning unit and this happened. ricoh belt.jpg It's hard to see with the relection but it looks like the bumps were formed from underneath . Help appreciated before I spend $ on new belt and new cleaning unit.
  • tsbservice
    Field tech
    • 8030
    Re: C5100Pro
    Looks like charge rollers inside belt are contaminated with toner clumps. Happens more often when belt/machine maintenance are overdue or/and compatible toners are used. Generally it's time for new image transfer belt unit now but Ricoh aren't exactly in my field expertise so more experienced guys can help better.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Re: C5100Pro
      Originally posted by leonardcahill
      Can anyone tell me what caused all the little bumps on my transfer belt. We just changed the belt cleaning unit and this happened. [ATTACH=CONFIG]47370[/ATTACH] It's hard to see with the relection but it looks like the bumps were formed from underneath . Help appreciated before I spend $ on new belt and new cleaning unit.
      Looks like the new belt wasn't installed correctly ie cleaning the unit before the belt was installed best to get ricoh credited service engineer to do
      Regards Mark
        Re: C5100Pro
        why isn't this in the ricoh copier forum?
        • copier tech
          • 8192
          Re: C5100Pro
          This is the key here with a Pro machine, replace ALL parts once they hit PM life or you will run into these kinds of issues.
