ricoh 1022 white stripes
  • KeviM
    • Oct 2019
    • 327
    #16
    Re: ricoh 1022 white stripes
    I think the guys have given you the best possible causes.
    Check your optics. Mirrors. Motor drive, cables/belts and scanner rails. Also those copies you made, you didn't say if you place the original directly on the platen glass or in the ADF. If it was fed in the ADF check your feed. Make sure it feeding smoothly.
    Also
    I would say try a good PCU or if you can rebuild 1. Be sure to put in OEM PARTS. Drum, Dev, blade. Check your charge roller and development drive gears. Replace if necessary.
    I hope this helps
    • manitos
      • Feb 2020
      • 5
      #17
      Also
      I hope this helps
      hi , adf or glass have same problem . i will check those too, thanks for suggestions ,i will see what i can find.
      • Mark Bbb
        • Jun 2012
        • 1662
        #18
        don't put new wine in old barrels
        • KeviM
          • Oct 2019
          • 327
          #19
          Also.... I know this is a long shot but hows your laser unit...
          Plus check your main charge roller. Make sure it is rolling properly and is clean properly.
          Hope this helps.
