ricoh 1022 white stripes
  • manitos
    • Feb 2020
    • 5
    hi all , i'm looking for help with this problem , i took a skyshot to show you , thanks in advance!
    • 37378
    Re: ricoh 1022 white stripes
    It could be the charge roller, drum or developer. Most likely the developer. it has possibly been running under toned for quite some time and has started pulling developer out of the development unit. Buy a new bag of Genuine Ricoh developer and replace. If you are use after market supplies, you are wasting money.
    • sandmanmac
      • 3979
      That machine uses the all in one Type 1027 PCU.
      But I agree is probably needs a new unit. That's where I'd start.
      It would be nice if the user had done something/ anything to resolve the issue before posting
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        +1 would be good to see some other samples and what's been done if anything
        Regards Mark
        • manitos
          • Feb 2020
          • 5
          ok guys !, this is weird ,this problem has been for quite some time , now i was going to order a bag of developer as slimslob advised , but it ocurred me for the first time to print the counter , and this happened:
          Counter directly from machine:
          A copy of the counter:
          A copy of the counter at max density:
          as you can see , the triangle is fine if i print directly from the machine
          • sandmanmac
            • 3979
            You obviously don't want to spend the money to have a tech on site to assess the issue, so my suggestion from thousands of Km's away is unchanged.....
            You're wasting your money by just swapping the dev in this machine, and it "technically" isn't available anyway, because, as I said, this machine takes a complete photoconductor unit (which includes the dev)
            • anothertech
              • 1762
              1+ Dude from Toronto is right.
              • skinnyb
                • Jul 2008
                • 291
                Yes. Change the PCU (if you can find one)
                Sent from my LM-V405 using Tapatalk
                  • 37378
                  [ATTACH=CONFIG]47438[/ATTACH]
                  [ATTACH=CONFIG]47439[/ATTACH]
                  [ATTACH=CONFIG]47440[/ATTACH]
                  You may also have a problem in the scanner section. Dirty mirrors, exposure lamp and or lamp regular, CCD/SBU or IPU.
                    • 37378
                    Most Type 1027 CPU if you can find them are rebuilt, even from Ricoh who labels them as Type 1027R.
                    • sandmanmac
                      • 3979
                      Even though you can't get the original from Ricoh, Precision roller still carries them (although I don't order from them here in Canada), I get my originals from NuTone Densi.
                      I can't explain how/why that's the case, but it is
                        • 37378
                        I think Precission Roller is where we used to get rebuild kits from. Did not include the developer but the instruction sheet gave you the Ricoh developer to use and provided a bottle to measure the proper amount. If I remember two bags of developer did three PCU. My boss tried some from another source one time, lower cost ha ha. The blades were too soft and failed in less than 2 weeks.
                        • manitos
                          • Feb 2020
                          • 5
                          ok thanks for the inputs ,i wish i had a tech nearby, but where i live(small town) i have to manage to fix the unit on my own . i'll check for a pcu but all the ones i could find at the moment costs more or less 100u$s , and comparing that price from precisionrolling site at 240 i dont think are very trusty .
                            • 37378
                            Do you at least have a service manual? If not Private Message me with your email address.
                            • manitos
                              • Feb 2020
                              • 5
                              yes i have it , it says "Model R-C2a/b(Machine Code: B022/B027)SERVICE MANUAL" , thanks!
