User guide for Ricoh Rex Rotary 1508 Aficio
  • marcweb31
    • 14
    hi i search user guide for Ricoh Rex Rotary 1508 Aficio where can I find them thanks?
    • 37532
    Re: User guide for Ricoh Rex Rotary 1508 Aficio
    Do an internet search for "aficio 1501 manual"
    • sandmanmac
      • 3981
      Hey Tim.
      slight typo...it should read Ricoh Aficio 1015 or 1018
        • 37532
        Originally posted by sandmanmac
        Hey Tim.
        I was misled by Precision Roller. Rex Rotary 1508 Equivalent Cross-Reference Guide
        • marcweb31
          • 14
          on
          • marcweb31
            • 14
            on that site I found only the tonner but not the manual ... where can I find the manual thanks?
            • TonerMunkeh
              Professional Moron
              • 3865
              On the serial number sticker on the back of the machine, there will be an engine number, i.e. B039. Can we have that so we can get the proper model number please.
              Hit it.
              • marcweb31
                • 14
                yes then:
                NRG 1802
                serial number:26201443
                when I start to print it stops after 3 pages without error on the printer apart from the darker display but only error on the pc it stops What can it be? .... I need the manual to read if it talks about this problem, thanks
                • mikadonovan
                  • May 2008
                  • 2931
                  Here's the user manual
                  NEVER ASSUME ANYTHING
                    • 37532
                    Originally posted by mikadonovan
                    And if he wants it in Italian?
                    • tsbservice
                      Field tech
                      • 8020
                      Slim, TS made a few posts in good enough English so I think chances are high he can use manual from mika.
                      • GIUBOSS
                        • 1436
                        what operating system are you using and with which driver? Which port are you using? When crashes what error does the machine or PC indicate?
                        Tomorrow I could look for the manual in Italian in the labyrinth of the warehouse, I will let you know with a pm
                        • marcweb31
                          • 14
                          thank you so much ."mikadonovan" yes it is just that.
                          In the meantime I have solved the problem of the print block was due to a different driver, now I have installed the one from the ricoh site and everything works fine.
                          yes Is there an Italian version?...i would be very grateful ... thanks
                            • 37532
                            If you are in Italy and you do a search for Aficio 1015 operator manual, it might bring up one in Italian.
                            Se sei in Italia e cerchi il manuale dell'operatore di Aficio 1015, potrebbe comparire uno in italiano.
                              • 37532
                              Manualslib also has the System settings manuals and the Service Manual but I don't know if they have them in Italian.
