MP3500 Only RPCS
  • espectra
    • 2
    MP3500 Only RPCS
    Hi, I have and old aficio MP3500, but only have RPCS. The windows 10 drivers it`s only for PCL6. How can install?
    Can use SD Card?
  • 8T2
    • Aug 2015
    • 257
    Re: MP3500 Only RPCS
    RPCS driver discontinued years ago. You can get latest PCL driver here
    Aficio MP 3500/4500 Downloads | Ricoh Global
    Sent from my WAS-LX1 using Tapatalk
    • GIUBOSS
      • 1436
      Can use SD Card?
      once you have downloaded the driver you have to look for it in the "Temp" folder or in the downloads, open it wherever you want. Add the "new printer" by creating a dedicated IP port and looking for the driver in the folder.
      what do you mean using SD card?
        • 37515
        If your MP 3500 has only support for RPCS printing nthen in all likelihood lack either the required memory or an the HDD needed to support PCL/PS3. The RPCS driver is still available but not listed for Windows 8.1 or Windows 10 because Ricoh no longer had a license to use RPCL for new products or new drivers for older products. On the driver page that 8T2 gave a link to click on "Choose other OS" and under Windows select the correct Windows 7 RPCS driver.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Don't forget to extract diver 1st
          Regards Mark
            • 37515
            The kit needed to add PCL printing to a RPCS only machine includes additional memory, an HDD and a SD card to install the firmware.
            • espectra
              • 2
              OK, can send me SD Card bin to install firmware? Memory and HDD is not problem.
              Thanks in advance.
                • 37515
                Thanks in advance.
                You have to order it entire kit from Ricoh or a used equipment wholesaler.
